Help with taillight clearing!
Old Jul 6, 2003 | 09:14 PM
frinxor's Avatar
Following Brian V's instructions on clearing my 97 tails, I'm stuck after i pulled out the taillight unit. I cant seem to seperate the black plastic housing and get to the orange part that i need to replace. What am i supposed to do ?
Old Jul 6, 2003 | 09:56 PM
1FSTMAX's Avatar
Did you remove the small 4 screws that hold the lens to the actual housing?
Old Jul 6, 2003 | 10:00 PM
frinxor's Avatar
yes ive removed the 5 small black screws that connect the black housing to the lens, heated all around and tried to pull it off. instead, i chipped off a corner. after several more attempts i gave up. i'm trying again tomorrow. am i doing anything wrong ?
Old Jul 6, 2003 | 10:05 PM
1FSTMAX's Avatar
You need to heat them for a long time, almost to a point of melting the housing. Then they will come apart.
Old Jul 6, 2003 | 10:31 PM
frinxor's Avatar
i'm not sure where exactly to heat them do i heat the center part with the black glue or do i heat around the edges of it all. does it fall apart after enough heating or do i pull?
my last attempt was i heated all around the edges of the entire thing and i pulled damn hard and it came off only slightly.
Old Jul 6, 2003 | 10:52 PM
taggate's Avatar
if the edges are heated enough you should need that much force to pull it apart. if the lense dont come apart throw them back in the oven and heat it some more.
Old Jul 6, 2003 | 10:53 PM
1FSTMAX's Avatar
Keep heating the edges, spread them a little heat them up some more and spread the lens. Keep doing that till they come apart.
Old Jul 7, 2003 | 12:25 AM
frinxor's Avatar
thanx. will try that again tomorrow. oven? i used a heat gun
Old Jul 7, 2003 | 04:47 AM
LiquidNine's Avatar
The alternate method of heating the light assembly involves baking the whole thing in an oven instead of using a heat gun.
Old Jul 7, 2003 | 08:00 AM
NYCe MaXiMa's Avatar
heat evenly in back and forth motions, going over the same spot.. heat the housing around the edges and don't hold it in one spot, keep moving.
Everyone cracks their 1st set or 2nd and 3rd
when you attempt to pry the lens from the housing, use extreme caution and don't force it. If it's not going smooth, then keep heating it. When you pry it, never grab the corners.. use the bottom of the light 1st. I also use a flathead screwdriver to help me out a little bit. but pull on other sides evenly, keeep heating, pull.. keep heating pull.. etc.. patience is the key
Old Jul 7, 2003 | 11:39 AM
n2o_matt's Avatar
where can i find the full set of instructions?
Old Jul 7, 2003 | 11:53 AM
patel_anu's Avatar
i used the oven method, about 225 degrees for 10 minutes and they came off pretty easy, but i did crack one lense, try the oven method if you can't get the heat gun to work
Old Jul 7, 2003 | 06:46 PM
99maxx-on19's's Avatar
i think i will try it 2nite and let u guys know what happen
Old Jul 7, 2003 | 08:08 PM
MrEous's Avatar
^ Jeff™
...the oven method definitely works best as it equally heats it all up making for an easier seperation...
Old Jul 7, 2003 | 11:48 PM
frinxor's Avatar
haha thanx for the help man.
Nyce Maxima: shouldve told me a little sooner =P i've cracked both lenses on that one frail corner that sticks out haha and i melted the lense with the heat gun so theres this big orange blob. lol. anyways, thanx guys
Old Jul 13, 2003 | 06:01 PM
yeah i cracked mine but i got it done wanna see?
Old Jul 14, 2003 | 09:47 AM
n2o_matt's Avatar
Is there a full set of instrctions for doing this some where? Can some one give me a link?
Old Jul 14, 2003 | 10:04 AM
not sure if it's still online, but I found the write up from "NickStam" to be one of the better ones with nice pics and directions.
otherwise, www.BrianV.net has one, then www.maximadriver.com should have it.
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
JoshG
Sep 5, 2015 10:10 PM
