codes 0302 and 0304
Old Jul 7, 2003 | 06:09 PM
ZuMBLe's Avatar
Welcome to the world of bad knock sensor and clogged EGR tubes.
Old Jul 7, 2003 | 06:35 PM
joaquink's Avatar
¿Hablas Español?
p0302 and p0304 are cyl 2 misfire and cyl 4 misfire respectively. If you had OBD1, then 32 and 34 are the EGR and KS. Check your plugs.
Old Jul 7, 2003 | 07:14 PM
ZuMBLe's Avatar
I'm pretty sure he's not using a scantool. So 0302 is EGR insufficient or excessive flow detected. Probably means the EGR tube is clogged. 0304 is the bad knock sensor code. The P-codes are generated by scantools. I don't think he's using a scan tool.
Old Jul 7, 2003 | 07:55 PM
jdavey26's Avatar
I am not using a scan tool.
Are there any on-line sites that have instrutions to repair these problems?
Old Jul 7, 2003 | 09:46 PM
ZuMBLe's Avatar
Use the search button on the top of the page. Type in "EGR Clean" and "Knock Sensor Replacement". You will get a lot of answers.
ZuM
Old Jul 7, 2003 | 10:53 PM
Y-MAX's Avatar
Newbie here but how do you guys get those diagnostic codes? Is there any device I should buy to read those codes? What's the scan tool you guys were talking about? Just curious.
Old Jul 8, 2003 | 04:48 AM
ZuMBLe's Avatar
Hi Newbie! Hit the back button and look on the top of the page. All will be clear. =P
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
