progress and kyb GR-2 question
Old Jul 10, 2003 | 12:56 PM
ohsonmaxima's Avatar
Alright guys, I need your help. I've been riding with my progress and gr 2 setup for awhile now, and everytime I hear a squeak or a loud bumpstop noise I get ****ed. I've read all the suspension FAQs and posts, and i'm still not sure what to do to make this go away. As far as I can tell, my setup should be alright. What can be done other than put my stock suspension back in?
thanks in advance
Old Jul 10, 2003 | 01:11 PM
JPMax's Avatar
What's next!?..
Did you use OEM isolator sleeves or wire wrap?
- If wire wrap, see if you need to replace them.
- If oem, you should have one on the bottom and one on the 2nd from the top of each spring. At least on the front springs.
Did you use OEM dustboots or KYB boots?
- People recommend cutting half the bumpstop off the OEM boots to allow more travel room for the struts.
- You could also try Motivational strut mounts if you want to add some additional travel room for your struts.
When you did the suspension job, did you change any of the other parts?
(Strut mounts, bearings, etc.)
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
maxima-junky
Oct 7, 2015 06:13 PM
Socalstillen
Sep 26, 2015 12:01 PM
