Floating feeling - need bushings?
Old Jul 18, 2003 | 07:23 AM
BillE's Avatar
I recently upgraded from the existing 205 15/65 S tires that were on my Maxima GXE to a lower profile 215 15/60 H tire - the Dunlop A2s. I also have a front tower strut bar and a rear anti sway bar.
However, at the same time, I had the rear struts replaced at Midas, just a basic replacement Gabriel strut--nothing fancy.
Now the car seems a little overwhelmed by the added grip of the tires. It corners fine at normal speeds, but if I push it hard at an exit ramp, the body seems to sway over the tires--I doesn't lean much, the antisway bar keeps the car relatively flat. It's more like an unsettingly side motion, as gravity pulls the back end out a bit.
The tires remain planted. however.
Question - would adding better bushings help? Or is this a matter of needing everything--struts all around, springs, etc? Anybody experienced this? Would I be better off returning the tires ASAP for the stock 65 series tires (still in H)?
Thanks,
Bill
Old Jul 18, 2003 | 07:26 AM
njmaxseltd's Avatar
Have your front strut replaced so the car is balanced a little better. You might as well throw the Gabriels up front to match the rears.
Old Jul 18, 2003 | 07:31 AM
MrEous's Avatar
^ Jeff™
I thought all Maximas float on (relatively) stock suspension? The difference between my car on stock springs and Eibachs were night and day.
Old Jul 18, 2003 | 07:34 AM
njmaxseltd's Avatar
Correct - The Maxima has pretty soft struts from the factory, especially in the rear. SE's are a little better do to a firmer rear spring.
The struts are what cause the floaty ride. Springs play a role too, but not as much as a set of performance struts do.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
