electrical and fuse help.
Old Feb 5, 2001 | 10:47 AM
NISMO808's Avatar
I replaced my foglights not too long ago and then switched back to my stock foglight bulbs after 2 days. However after doing so, they don't turn on anymore. I tried putting in the aftermarket bulbs again to see if it was just a bulb problem however it still doesn't turn on.
Also my left cornering light went out so I thought it was burned out and then tonight I noticed that it turned on this time. Something fishy is goin on here and I wanna know what's up. Any insight on this will be much appreciated. YA think it's a fuse problem?
Al.
Old Feb 5, 2001 | 11:26 AM
Grifter's Avatar
Fogs
Nismo,
I had a similar problem with my max. Maybe this will help.
I replaced my fog with an H3 bulb 100 watt. That is the wrong one. It needs to be a 55 or 65 watt. When I used the 100 watt bulb it blew the fuse. The fuse compartment is located in the 4th gen's on the driver's side under the hood and is a 15 amp. REPLACE YOUR BULB FIRST or you will just blow another fuse. Try that and see if that works. Hope that helps.
Old Feb 5, 2001 | 11:44 AM
NISMO808's Avatar
Thanks Josh for the swifty reply. I'm gonna stop by track auto on my way home and buy a fuse. That's most likey the problem the more I think of it. Thanks again,
Al.
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
