How do you adjust the timing on a 4th Genration ??>>
Old Aug 22, 2000 | 10:12 AM
JULIAN's Avatar
I checked the timing on my car this weekend and it is around 5-8 degrees BTDC, I read in the Factory Service manual that it should be 15 +/- 2 degrees. So how do I advance it ??
Old Aug 22, 2000 | 10:16 AM
Keven97SE
You can't ->
You probably didn't check the timing right, either. The factory service manual lists a detailed, specific driving routine you must follow before checking the timing.
The timing is electronic. There's no adjustment you can make. The good thing is it's nearly impossible for the timing to be off more than a degree or two either way.
Old Aug 22, 2000 | 10:40 AM
JULIAN's Avatar
I'm pretty sure I did it correctly >>>>
I have an AUTO so it must be in Neutral, car had to be in operating temperature which it was, rev the car 2-3 times to 3000 rpm and then let it idle for about 30 secs to stabalize, take reading. Am I missing anything ???? Or doing anything wrong ???? Please let me know. I switched out my ECU to the Stock ECU and it was still the same 5-8 degrees BTDC. Here is what it looks like:
__ First Marker
__ this is where my Timing is at(the little pointer)
__ 15 Degrees
__ 20 Degrees
Old Aug 22, 2000 | 11:24 AM
Keven97SE
I don't have the manual in front of me ->
But I seem to recall also needing to run the engine at like 2/3000 rpms for something like 2 minutes also. I'll need to check the manual to find out the exact specs.
Old Aug 22, 2000 | 01:25 PM
Slickismax's Avatar
Well, the 4th gen has a chain, not a belt. I don't think there is a way to adjust it. The only way I could see it being off is if it jumped a few teeth. If thats the case, I think you would know it was off.
Old Aug 23, 2000 | 12:59 AM
hodgeee
There is also an electric plug that changes the vacuum
I remembered checking mine, and the manual stated that there was a plug that had to be pulled first, that would change vacuum. Without doing this, the reading would be way off. The only way to change the timing is by connecting the computer of the car to the computer that they have at the Nissan service center. Since we have distributorless ignitions, it is entirely controlled by the computer. Any distributorless ignition works the same. If you think that your timing is off, take it to Nissan, and tell them that all you want is to check the timing. They should charge you no more than 10 bucks.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
