Cruise Control Shuts Off
Old Jul 29, 2003 | 11:29 AM
99MAX's Avatar
i have a 99 se auto matic with every option available, here is the problem: if i set the cruise control and after it is set, i use either one of my power window controls it shuts off the cruise control when the window is alowed to go either all the way up or all the way down. if i stop the window short of going all the way it doesn`t shut off, what is up with this,
Old Jul 29, 2003 | 12:32 PM
njmaxseltd's Avatar
Does it shut the whole crusise off or just disenguage?
Old Jul 29, 2003 | 12:55 PM
99MAX's Avatar
it just disengauges when it happens i have to hit the resume\accel button on the steering wheel and i can continue cruising
Old Jul 29, 2003 | 01:41 PM
njmaxseltd's Avatar
Interesting.... Very interesting....
Put a volt meter on your electrical system and just verify you indeed have a strong 13.5 volt charge while your car is running. If your alternator is weak and your running voltage is a bit low, it may effect how other electronic devices are running. Your cruise control may be very sensitive to low voltage.
Does this happen with the headlights on as well as off?
Old Jul 30, 2003 | 04:42 AM
99MAX's Avatar
yes it happens with the lights on and off...i`ll check the volts thanks for the advice
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
