HELP!!! No pressure in clutch hydrolic system
Old Jul 31, 2003 | 02:26 PM
wrongway15's Avatar
I tried to install speed bleeders on the clutch but i had the wrong size ( realized this after i took out the bleeder screw and lost pressure)
how do i build this back up?
the guy on the phone at nissan said i didnt disconnect the bleeder screw but it was the hydrolic screw or something like that (the one up at the end of the metal line near the top right corner of the engine bay near the windshield)
please help i need to make a 5 hr drive to MD as soon as i get this fixed
oh and i cant get the car in gear even is the peddle is all the way down and the car is on (but it will if it is off and the peddle is up or down)
whys that?
thanks
Old Jul 31, 2003 | 03:17 PM
time2reup's Avatar
there are two bleeder screws for the clutch the one you are talking about which is easy to see and then a lower one closer to the engine block itself...you will have to fill up your reservoir with fluid and then bleed it until you get all of the air back out....check out the motorvate site for pics...
http://www.motorvate.ca/mvp.php/803
Old Jul 31, 2003 | 03:18 PM
wrongway15's Avatar
thats what ive been doing but i dont seem to be able to be able to get all the air out i guess...this sux
Old Jul 31, 2003 | 03:21 PM
time2reup's Avatar
yeah when I replaced the lower hose in my system I bled it for like 2 hours and didn't get it all out...but got the car driveable...couple days later I bled it some more and that had given the system a chance to move the air to the bleeders....no problems since then...
Old Jul 31, 2003 | 03:22 PM
wrongway15's Avatar
how much brake fluid did you need to bleed for two hours?
Old Jul 31, 2003 | 03:23 PM
time2reup's Avatar
I think one and a half bottles...
Old Jul 31, 2003 | 03:24 PM
wrongway15's Avatar
do i need to worry about the lower bleeder screw? i didnt remove that one
Old Jul 31, 2003 | 03:26 PM
time2reup's Avatar
I have never used those speed bleeders so I don't know exactly what their directions are...but you should bleed the bottom half of the system till it comes back clean then bleed the top half...
Old Jul 31, 2003 | 03:35 PM
wrongway15's Avatar
ok well im not using the speed bleeders, it doesnt fit...using original screws...but thanks
when i get bubble free fluid will the peddle be like normal and come up when i push down on it?
Old Jul 31, 2003 | 03:47 PM
wrongway15's Avatar
ive bled the clutch before just fine, i dont know whats up now tho
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
