Checked ecu for codes today!! Im ****ed
Old Aug 4, 2003 | 08:59 PM
maxspeed96CT's Avatar
The original VQ...
I have ben having hesitation problems so i ran my ecu for codes today. I got 1 long 2 short, and 3 long 4 short, that is knock sensor and mass air flow sensor, could this be possible to have all this **** broken and no CEL, could this be a mistake ?? and were is the cheapest place i could get these?
Old Aug 4, 2003 | 09:04 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
somethimes one Problem could set off another code.. Don't mean you have MAF problem as well as knock sensor problem. IT could be either or....
Old Aug 4, 2003 | 09:18 PM
RA030726's Avatar
I'm nutty for Nissans
knock sensor is a ghost code. check your ecu again to see if they are still there. eBay has the KS for $80-$100. The MAF is like $350-$400 at the dealer.
Old Aug 4, 2003 | 10:07 PM
The original VQ...
well i have be gttin bad gas milage so i think im gona change the knock sensor, plus i dont wanna spend that much on a MAF and find out its not broken. could somethin like a vacum leak or something small cause this code?
Old Aug 4, 2003 | 11:42 PM
MaximaVQ97's Avatar
You Might Want to Check the MAF first before you do anything .. check the grounding and inside the MAF to make sure everything is there and connected... most likely you MAF has a problem which is also causing the KS Code to Show up, and yes check for vacum leaks..
-Anthony
Old Aug 5, 2003 | 04:23 PM
The original VQ...
damm i just rembered no that i took my MAF apart, my dumb a$$ took the screen out when i put my intake on, could that have anythin to do with it?
Old Aug 6, 2003 | 05:40 AM
Jatan's Avatar
Did you turn the car on when some of the wires were out? I turned on my car with the intake off and now I have a CEL on. The stupid plastic won't come out so I can't check it right now. Reset your CEL so it goes away and then if it comes back, you have something wrong.
Old Aug 6, 2003 | 05:50 AM
njmaxseltd's Avatar
-Anthony
Don't change the KS, thats prolly not your problem. A bad KS doesn't cause hesitation, it causes a lack of power. You have a hesitation which is most likely caused by your failing MAF sensor. A failing MAF will also trigger your KS because your engine isn't running correctly.
Old Aug 7, 2003 | 01:20 PM
w30post's Avatar
Do you guys clean the MAF? I cleaned the one on my 240SX and my neighbors F150 with good results. I use 90% alcohol and a artist brush. I haven't looked at the Maxima style one yet. I visit this board for my sister's 95 Max so I am not totally on the wrong board.
Old Aug 7, 2003 | 01:53 PM
ManualMaxima's Avatar
5th Gen till she dies!
what the hell is knock?
Old Aug 7, 2003 | 02:49 PM
2naboy's Avatar
The knock sensor does cause hesitation. when I was having this same problem, I changed my ks and the hesitation completely went away.
The maf causes stalls and some hesitation during idle. I went to the dealership and the technician suggested that, since the maf is meant to last for a very long time, I might want to go to a junkyard and find one it will work the same. I bought it for $70 and I have not had any problems with it. That was about 70000 miles ago.
Old Aug 7, 2003 | 03:08 PM
w30post's Avatar
Two different types of "knock".. One is from the ignition spark arriving too early and the explosion tries to reverse the piston travel. The other bad one would be excessive bearing wear in the rod and main bearings. You really don't want the second one. The Nissan 240 and trucks use the same motor and the timing chain systems suck in them. When the timing chain guides go bad they drop shavings into the oil pan and starve the oil strainer of oil. This causes low oil pressure and fast wear in the bearings. It also causes a knock above 3000RPM. Don't know if Maximas are prone to this as the timing chain tensioner chatters in the morning. Sorry guys I got a little off topic here.
Old Aug 7, 2003 | 06:16 PM
ZeRo MaX's Avatar
anyone know the website that tells u how to check ur ecu.. my light came back up.. last time i didn't check it.. and now i think i should..
Old Aug 7, 2003 | 06:56 PM
Jatan's Avatar
Top of forum: "Important: ECU fault code diagnosis ("HELP! MY CHECK ENGINE LIGHT IS ON!!")"
CorollaULEV
30
Aug 9, 2021 08:11 PM
Slamrod
Sep 3, 2015 07:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
Trin1j23
Aug 12, 2015 08:31 PM
