Ghost Code
Old Aug 4, 2003 | 10:41 PM
p-trap's Avatar
Ghost Code
OK now. I've been looking closely @ the threads regarding check engine codes and have noticed the term "Ghost Code" what is that? For example, on my 95 GXE. I pulled the code 0304 (K-Sensor) then it puked the code 0407 which allegedly means Crankshaft Position Sensor is bad. So which if any of those is a "Ghost Code". P.S. My check engine light came on after I replaced the starter. Could that procedure have affected those sensors????
Old Aug 5, 2003 | 07:44 AM
p-trap's Avatar
After getting those codes, I reset the ECU and the check engine light has not come back on since then (8/1). I don't get it.
Old Aug 5, 2003 | 09:02 AM
blackmax95's Avatar
If you had a bad crank sensor i would think the code would come right back and your car probably wouldn't start... I would only make an issue of it if they return..could also be an intermitant problem...
Old Aug 5, 2003 | 09:19 AM
kenju4u's Avatar
if in dout test with a Ohm/volt meter before replacing. A few months ago my speedometer went bad and it was giving me a bad speed sensor code. I replaced the speed sensor and it didnt fix the problem...this is a prefect example why we should always test the component before replacing it.
Old Aug 5, 2003 | 11:20 AM
njmaxseltd's Avatar
Re: Ghost Code
Your starter replacement really should have nothing to do with it. The Ghost code in your case would be the 0304 KS error.
Consider yourself lucky.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
