Line Pressure (Dropping) Resistor Specs
Old Aug 5, 2003 | 09:37 AM
Zirafa's Avatar
Does anyone happen to know what the resistance of the line pressure resistor is supposed to be? I am talking about the resistor that some unplug to get faster shifts with their AT.
I just want to check if its within specs or not. It may be 10-15 Ohms but the member that said that wasn't sure. I checked Haynes and Chiltons and it's not there. If someone has a FSM and look it up I'd appreciate it...
Old Aug 5, 2003 | 09:48 AM
Jime's Avatar
12 Ohms
Old Aug 5, 2003 | 09:53 AM
Zirafa's Avatar
Originally posted by Jime
12 Ohms
Thanks, Jime!
Since you knew that, perhaps you know this - would it matter if mine is 13 Ohms? I get harder than usual shifts.
Thanks again.
Old Aug 5, 2003 | 09:57 AM
kenju4u's Avatar
what is this? This is the first time i hearing about it...is this a MOD? whats its do and how hard is it to do?
Old Aug 5, 2003 | 10:02 AM
mzmtg's Avatar
Minister of Silly Walks
I thought it was 12 kOhms
Old Aug 5, 2003 | 10:10 AM
Zirafa's Avatar
It must be 12 Ohms, not 12 kOhms because I checked mine yesterday and it was 13 Ohms. I doubt that it would drop from 13,000 Ohms to 13 Ohms if it was bad on my car and make shifts a little firmer - I think it would slam into each gear if difference was that big.
Old Aug 5, 2003 | 11:09 AM
Zirafa's Avatar
So it's supposed to be 12 Ohms and mine is 13 Ohms - that's almost 10% difference. Anyone think that 10 % would make any difference in smoothnes of the shifts?
Old Aug 5, 2003 | 11:12 AM
azflat4's Avatar
My car shifts VERY hard into 2nd...I'm also curious about this
-Ryan
Old Aug 5, 2003 | 01:20 PM
Zirafa's Avatar
"Will the real AT expert please stand up,...!!"
Good; now sit down and tell me this:
Do you think a 10% increase in AT fluid line pressure would make a noticable difference in shifts
Old Aug 5, 2003 | 01:33 PM
Jime's Avatar
The difference between 12 and 13 Ohms will make no difference Zirafa. I have tried pretty well every resistance from 12 to 0 and 12 to 1000 to try and find a middle ground for the line pressure. Its not there, its either normal or full line pressure there is no in between using the drop resistor.
Old Aug 5, 2003 | 01:56 PM
Zirafa's Avatar
Thanks again, Jime!!!
That's all I wanted to know.
Old Aug 5, 2003 | 04:23 PM
RA030726's Avatar
I'm nutty for Nissans
This is a mod, no its not hard, and it is only for automatic. From my understanding you install a switch to disconnect the resistor, well that's all I did. Go to mzmtg's homepage to see his picture of it. I think he was the first to do it, he also had a write up somewhere. Anyway cut either wire going to the litte metal resistor thing (on the drivers side strut tower), and install a switch inside the car. Mine is in the kick panel, mzmtg's is in his coin holder, jime's is a WOT switch (I think) so his set up is a little different Note: this can trip your MIL light, and the O/D light flashes a code on startup (after using it). Someone else add there imput if different.
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
bryants95max
Oct 2, 2015 12:52 PM
The Wizard
24
Oct 1, 2015 08:47 PM
ballerchris510
Sep 23, 2015 08:46 PM
