? for NE1 with 18" x 8.5
Old Feb 6, 2001 | 10:20 PM
JonH in Philly
Do you have any problems with rubbing or finding tires?
Do you think that you should have gone with 7.5" or 8" wide instead.
Thnx in advance
JonH in Philly.
Old Feb 6, 2001 | 10:29 PM
MaxedBandit's Avatar
Thnx in advance
JonH in Philly.
I only have 8" wide, but when they put the 8.5" on, it was fine, they just didn't have all 4 rims and they wouldn't have them for a long long time. I haven't had any problems with rubbing, and I'm almost positive I wouldn't have had problems with the 8.5's....as long as you use 245's and maybe even 255's (not sure about this). Also, depends how low your car is.
Old Feb 7, 2001 | 05:53 AM
cyclemax's Avatar
I have Zenetti Valeos 18x8.5 45mm offset
IMHO, a perfect fit. Car is lowered with H&R's and looks great. Tire size is 235/40/18. Remember, the offset is what determines the location of the tire in the chassis, so the diff between an 8 and 8.5 (provided the same tire and offset) is just the sidewall angle. The tread will end up in the same place.
Check the tire mfgs specs for the optimum rim width (7.5" is too narrow for a 235/40).
Also, 245's might be a bit too "bulky" looking for the front of the car.
Old Feb 7, 2001 | 06:09 AM
Mannylove's Avatar
I went with the Enkie V1 18 x 8.5
No problems here. Lowered with Eibachs.
MastaShimz
28
Nov 18, 2001 07:39 AM
ih8gol4s
Oct 19, 2001 10:13 AM
MaxPower2K2
Oct 16, 2001 09:21 AM
MaxPower2K2
Oct 14, 2001 10:10 PM
