e-brake light randomly comes on...
Old Aug 7, 2003 | 11:02 PM
Jepht20's Avatar
Custom User Title...
sometimes when i start my car it's on and won't go off even if i make sure the brake is disengaged(sp?). then randomly it turns off a few minutes after driving. and on occasion, turns back on when driving. i just got new front pads and rotors last week but everything feels great. i also tried fixing my gauges and had the cluster out but am not sure if that would cause it to malfunction. any ideas?
Old Aug 7, 2003 | 11:13 PM
95GreekMaxSE's Avatar
fill brake fluid resevior to max
Old Aug 7, 2003 | 11:25 PM
Loe max's Avatar
mine did that for awhile. I changed opened up the rear calipers and took out the pads and put them back in. For some reason, that ended that problem You can give that a shot, its only a 15 min job
Old Aug 8, 2003 | 08:41 AM
cam_honestiam's Avatar
I had same thing two days ago. As mentioned above, the first thing to check would be your brake fluid level. Checking anything else first is a waste of time (refill with DOT 3 brake fluid).
Old Aug 8, 2003 | 09:45 AM
pocketrocket's Avatar
for the brake fluid in the reservoir.
It could be that with the motion of the car, the low level switch is being triggered and that switches on the brake warning lamp.
If your reservoir is full, then it would either be:
a) faulty brake level switch
b) faulty pkb sw
c) other (wire short, etc)
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
