Performance fuel injectors
Old Aug 10, 2003 | 05:39 PM
Alan's Avatar
Can you tell me where to get performance fuel injectors? I've a 95 w/ 126K and the stockers are starting to die one at a time. I've replaced one but more are starting to go and I don't believe in going stock if I don't have to. I'm gonna put on a cold air intake while I'm at it since I'm in AZ.
Old Aug 10, 2003 | 10:20 PM
joew's Avatar
are you using the hole saw to cut?
Old Aug 11, 2003 | 05:26 AM
mzmtg's Avatar
Minister of Silly Walks
1. How do you know your injectors are dying and it's not some other problem?
2. What other mods do you have that would require hihger flow injectors than stock? Aftermarket is not alwyas better or needed...
Old Aug 11, 2003 | 06:13 AM
njmaxseltd's Avatar
There is no such thing as a "high performance" fuel injector. Fuel injectors are sized to deliver X amount of cc's per impulse. They must be sized correctly in order for your car to run right. Increased air flow (BOOST) might require larger injectors. Other then that, you must stick with the OEM sized injector. Weather you get them from Nissan or aftermarket really doesn't make much difference.
Old Aug 13, 2003 | 12:44 PM
Alan's Avatar
Thanks for the info. I'll find the best for stock ones.
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
