Car dies with air filter on....??
Old Aug 10, 2003 | 08:26 PM
JerzMax's Avatar
Soon as I start the car, idle goes up and just drop downs and dies. I have a CAI so I took out the air filter and it idles fine. Soon as I put the filter back on, the car dies. I replaced the filter with an APC (not K&N which it orginally was) about 2 months ago, worked fine till now. I replaced the MAF, cleaned IACV, cleaned throttle body, and checked the TPS. I don't know why the car shuts off when putting the air filter on? Can anyone help me out?
Thanks...
Old Aug 10, 2003 | 08:33 PM
KINGMAX's Avatar
Sounds like a MAF or IACV but sounds like you went about everything right, I guess I would double double check everything was connected right.
Old Aug 10, 2003 | 08:45 PM
JerzMax's Avatar
I had this same problems about 3 weeks ago where I would start the car and it would then die. So went to junkyard and bought a MAF, replaced it and it started. After a week or so, my idle would jump around alot and got the EGR code, but the car was still running. So the goal for today was to clean the EGR, took it out, cleaned it, put everything back together and bam, I'm back to square one. So then I started playing around with the filter and got this conclusion, but know the solution
Old Aug 10, 2003 | 09:14 PM
JDogg96's Avatar
If you're pretty sure it's the filter giving you problems, you might want to try a K&N like it originally was (you can always clean and oil the original filter if it is not damaged)
Old Aug 11, 2003 | 06:00 AM
JerzMax's Avatar
That's my next step is to buy a K&N filter, anyone know where I can buy one ASAP? I know straus and pep boys don't have it.
Old Aug 11, 2003 | 06:04 AM
njmaxseltd's Avatar
I can't see any reason a filter, unless it's clogged so bad air cannot get through it would cause your car to die like that. It doesn't make sense. Something else is being effected by your CAI. The MAF would be your best bet.
Old Aug 11, 2003 | 06:07 AM
JerzMax's Avatar
I already replaced the MAF from the junkyard. And the funny part is that it was working last week even with my old MAF. I tested the MAF sensor, how do I test the MAF itself?
Old Aug 11, 2003 | 09:48 AM
JerzMax's Avatar
Anyone? I need my car running asap otherwise I'll be unemployed..
Please help...
Old Aug 11, 2003 | 09:55 AM
Chino's Avatar
I feel your pain. Yesterday my Intake system broke off in between the resonator and the MAF (I have a HKS pop charger) and I can't attend work neither until I get it fixed. I might duct tape it or wait until my Frankencar gets here (I ordered it last Tues).
Old Aug 11, 2003 | 11:19 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Please help...
you should be able to go into autzone, pep boys, or advance auto with a part number and have them order. i used to work at advance and we were about to get most k&n from the warehouse next day. we had to order before 5 or close to that. try calling one with a part number and see if they can get it by tomorrow.
Old Aug 11, 2003 | 12:27 PM
JerzMax's Avatar
Does anyone know the size for the Place Racing CAI K&N filter or product # ?
Lakersallday24
Jun 16, 2019 01:35 AM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
