How many different things can cause fluid to not come out of WW nozzle?
Old Aug 12, 2003 | 09:47 PM
NickStam's Avatar
One of mine is not dispensing WW fluid. Boo.
Old Aug 12, 2003 | 10:36 PM
minsbang's Avatar
1) freezes (in the winter)
2) no fluid
3) fluid line is not connected correctly
4) when you're trying without the car keys
5) something's covering it.. like a chewing gum
6) hole melted
7) something's wrong with the wiring
i guess i can think of 7 as of now..
Old Aug 12, 2003 | 10:53 PM
sryth's Avatar
Mine had wax in it...that sucked.
Old Aug 15, 2003 | 08:50 AM
NickStam's Avatar
Originally posted by minsbang
1) freezes (in the winter) it's summer
2) no fluid it's coming out the other one
3) fluid line is not connected correctly i'll need to check
4) when you're trying without the car keys ?
5) something's covering it.. like a chewing gum negative
6) hole melted hmm
Old Aug 15, 2003 | 08:52 AM
deezo's Avatar
Try to use a needle to clear it.
Old Aug 15, 2003 | 12:25 PM
sryth's Avatar
Toothpick worked for me
Old Aug 15, 2003 | 06:30 PM
97RxMaXsE's Avatar
same deal here.
Yeah I am having intermittent problems with the squirtters too. One stupid nozzle cost 20 bux. It could also be the windsheild washer pump.
Old Aug 15, 2003 | 07:59 PM
Jon91SE's Avatar
Pusssseeeehhhh
Dirt in your reservoir.
Old Aug 16, 2003 | 08:04 AM
dmBK's Avatar
How 'bout them cliffs?
the hose is crushed by the hood, by the passenger side (mine was).
Old Aug 17, 2003 | 01:56 AM
98BLKONBLKSE's Avatar
Here Here. Mine was crushed by the hood too. I could hear the pump pumping, and when I lifted up the hood, and tried it, low and behold, the bugger was working.
Old Aug 17, 2003 | 07:36 AM
NickStam's Avatar
i tried that, but it wasn't the problem.
Old Aug 18, 2003 | 07:58 PM
Terran's Avatar
Try disconnecting the nozzles from the hose and blowing through them--worked for me. You could also try blowing through the hose's to make sure they're not clogged but be careful because the WW fluid will overflow from the tank pretty quickly.
Mar 12, 2020 12:06 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
captchaos
Mar 15, 2016 12:18 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Maxxx10
Sep 13, 2015 03:16 PM
