Side Marker Light Wiring Question?
Old Aug 13, 2003 | 06:48 PM
WOODYMAX98's Avatar
I just got my side marker lights and have them installed. They have three wires coming out of them, BLack , Red, and yellow. I have the yellow and black hooked up to the turn signal lights, but were do I hook the ignition wire if I have them to be on with my headlights but not on all the time. If I hook it to the radio ignition they stay on all the time. Thanks for the help
Old Aug 14, 2003 | 04:12 AM
Albertt's Avatar
Re: Side Marker Light Wiring Question?
They should only blink with your turn signals.
Old Aug 14, 2003 | 06:02 AM
WOODYMAX98's Avatar
Ok. Then where do I connect the 12 V red wire?
Old Aug 14, 2003 | 02:24 PM
WOODYMAX98's Avatar
These are the aftermarker tiny ones that you have to drill into your fender. Who has hooked these up?
Old Aug 15, 2003 | 04:27 PM
WOODYMAX98's Avatar
Old Aug 15, 2003 | 07:40 PM
MIXXMAX's Avatar
You only need to use two of the three wires to make them do what you want them to do....blink with your turn signals right? I'm not sure why they have three wires. I had these installed on my '95. There were only two wires--positive and ground. Probably, the third wire on yours is a "constant 12V" feed. You don't actually need this. If you tap into your turn signal harness, you should have no problem.
vingodine
45
May 21, 2016 12:46 PM
rtirbany
Sep 8, 2015 11:46 AM
doobadoo
Aug 15, 2015 06:43 PM
98nismomax
Aug 13, 2015 12:44 PM
papo99
Aug 9, 2015 07:32 AM
