Polargs on Corner Lamp..
Old Aug 14, 2003 | 12:13 AM
MienMaxima's Avatar
Hi, I just purchased a pair of Polarg M-14 Bulbs for the corner lamps (the ones next to the headlight assemply), and I was wondering if anyone knows how to install it ?? Do I have to pop the lamp assembly out i.e, flathead, or is there some lamp assembly on the back I'm not seeing ?? Any ideas ?? (Newbie here)
Old Aug 14, 2003 | 12:56 AM
Nismo's Avatar
you can either pop it out or do it the hard way without removing it by taking out the turn signal lights and reach your hand up there. the bulb harnesss is on the bottom of the light thats why you cant see it.
Old Aug 14, 2003 | 07:20 PM
MienMaxima's Avatar
The only thing that makes me nervous is that by "popping" it out, I might crack or damage it. Plus, I notice some sort of rubber or foam insulation in and around the edges, presumabley to keep rain and moisture out.
Old Aug 14, 2003 | 08:21 PM
Nismo's Avatar
when you pop it off, after you take off the screw on top you have to start by popping out the side closest to the headlight. what I did was get a huge flathead screwdriver and stick it in the crack between the headlight and corner light and slowly pry it out until it comes loose. its held by a ball-in-socket type deal so you have to pull hard to pop it out. you'll see how it is once you get started
Old Aug 14, 2003 | 08:32 PM
MienMaxima's Avatar
Ohhh.....so you have to unscrew it FIRST before you start popping it out..I see...so it's ok then with the foam rubber insulation and it won't leack or cloud up afterwards ?
Old Aug 14, 2003 | 08:46 PM
Nismo's Avatar
yea have the hood open and you will see a screw holding the corner lamp onto the headlight. no it wont leak since the only opening to the corner light is a tiny hole on the back of the housing
Old Aug 14, 2003 | 09:00 PM
pocketrocket's Avatar
The foam is not for sealing the lamp ... it's just a rubber strip that runs alongside the lamp itself.
I have comparison pics of Polargs & Silverstars vs regular on my homepage, page 2.
By the way, if you're popping the lamp out with a flathead screwdriver, I would recommend using a rag or something to avoid chipping or scratching the paint around the clearance lamp housing.
Old Aug 14, 2003 | 10:47 PM
MienMaxima's Avatar
Thanks for the tips guys ! I'll definately get on the project ASAP !
Old Aug 14, 2003 | 11:14 PM
leprosybear's Avatar
i thought the polarg bulbs aren't the correct wattage for the corner lamp. Will they burn out quicker since their wattage is lower? 21w instead of 27w?
Old Aug 14, 2003 | 11:24 PM
MienMaxima's Avatar
Is this true ?
Old Aug 15, 2003 | 12:39 AM
Nismo's Avatar
I and alot of ppl use polargs in there with no problems
Old Aug 15, 2003 | 04:47 AM
Yeah ... I'm with Nismo on this.
Polarg bulbs are rated at automotive voltage, so they will not burn out quicker or last longer. The power consumption (wattage) of bulbs are controlled by the bulb itself based on the resistivity of the filament.
Old Aug 15, 2003 | 09:48 AM
simbany1's Avatar
"resistivity" - interesting
I have polargs in my clearance (with the clip off the nub mod) but don't like the look. A little too blue for me. I have Blue Visions in my sides and Cool Blue 9004's and they match up nicely. IMO I think the whiter looks better and my Cool Blue's light up the road pretty nicely. Def worked well in the pitch black roads last night!
Old Aug 15, 2003 | 02:58 PM
mah English ain't zo good.
Oh well, hopefully it gets the point across. Resistance sounded funny in the sentence. Too Star Trekky.
Old Aug 15, 2003 | 03:09 PM
simbany1's Avatar
Just playin'. I got the point...
Old Aug 15, 2003 | 07:21 PM
MienMaxima's Avatar
*sigh*...well.....I got the corner lamps off....However, I'm afraid i broke the bracket that attaches to the "ball & socket". I have no idea how that thing just pops out. My questions is, will it affect anything in the car during hard rain and winter snow ? Is it ok ? I mean, personally, I saw to need to attach it that ball & socket. THe screw on top should have been suffice.
Old Aug 15, 2003 | 09:36 PM
Nismo's Avatar
the screw will be fine. we actually took off the plastic socket that holds the ball in because it just makes it easier to remove and it holds on good without it anyways. dont worry about water and all that since it wont get back there
Old Aug 17, 2003 | 10:00 AM
MienMaxima's Avatar
So your saying that even without the that ball joint in place, the lamp assembly should be fine ?
Old Aug 17, 2003 | 01:08 PM
Nismo's Avatar
just as long as you have that screw on the top you should be fine
Old Aug 17, 2003 | 01:32 PM
MienMaxima's Avatar
COO ! Thanks Nismo !
NERDJUSTBNME
Sep 30, 2015 03:20 PM
03VQMAX
Sep 25, 2015 04:19 PM
Blkkn8
Sep 22, 2015 06:37 PM
tnewbs
Aug 28, 2015 10:15 AM
wingsfan24
Aug 15, 2015 07:35 PM
