Auto to 5spd conversion
Re: Auto to 5spd conversion
Originally posted by max88q
How much is it and how long does it take?
It took me about three hours to install the clutch pedal (I thought that was the hardest part, but I hate working up under the dash) and clutch master cylinder. Then the next weekend I spent two full days pulling the auto tranny out and installing the cltuch, manual tranny, new driveshafts, shift linkage and bleeding the clutch.
I'll never forget the feeling of elation I had driving the car with the manual for the first time (especially after the weird jingling noise went away when I made the first right turn).
Man I might have to plan a nice vacation to take care of this from one weekend to the next.
5 speed conversion...well let me say that I've also done this, in fact this weekend and I'm not quite done, need to bleed the clutch and need to make sure that all electrical components are hooked up as I did an engine swap along with mine. I put in a 97 engine into the 95...and ended up switching harnesses....man...I'm tired...but I have some questions for the 5 speed conversion guys...how are you supposed to bleed the clutch system?...also in the 95 where did you run the clutch lines? is it in the engine bay underneath the brake master cylinder? in the 95gxe it had the canister there...and I'm wondering what you guys did to bypass that if anything.
Thanks,
O
Thanks,
O
Well if you have ABS, running the hydraulic lines is a pain but if you take off the brake master it is much easier. Also to bleed use the upper bleeder first just the way you would do the brakes. Then once that is buble free go to the lower bleeder on the slave cylinder. After that is free of bubles your all set.
Calabar
Oct 5, 2015 09:57 PM
ef9
Oct 4, 2015 08:43 AM
