Re: Buzzing sound in Rear
Old Aug 16, 2003 | 04:05 PM
ZeRo MaX's Avatar
Not sure where it's coming from.. it happens when I accelerate when i first start the car.. it will last for about 2 - 3 mins.. after that.. when i push the gas (accelerate) it's gone....
any help would be nice!
Old Aug 16, 2003 | 10:42 PM
led1225's Avatar
can you figure out if its the left or right side?
does it go away if you pull up your handbrake during the sound
if so i had something similar to this and found out i needed a new caliper since it clamped down too much
Old Aug 18, 2003 | 06:12 PM
ZeRo MaX's Avatar
i believe it's on the right side (the passenger rear)....
Old Aug 18, 2003 | 10:34 PM
led1225's Avatar
At first I thought it was my subwoofer getting some kind of discharge since it sounded like a bass sound. Then i realized it seemed to change when i braked/ handbraked. I jacked my rear left wheel up (thats where it seemed to come from) and it was clamped down pretty tight. It didnt give off the free spin it normally does so I changed the caliper. Its been gone since so maybe you can jack yours up and see if you can rule this out.
Old Aug 20, 2003 | 11:26 PM
ZeRo MaX's Avatar
still not sure what it is... still happenin...
Old Aug 21, 2003 | 12:58 AM
Lost_N_a_97Max's Avatar
coming from outside or inside the car?
My 6X5 rear speakers made some crazy noises.... center plastic piece popping all day long.
Old Aug 21, 2003 | 10:07 AM
Thaniel's Avatar
I had a rear wheel bearing go bad. Made a sound kind of like a rattly exhaust. Just throwin out ideas.
Old Aug 25, 2003 | 10:09 AM
ZeRo MaX's Avatar
actually it might be my wheel bearing then.. it's sounds like a rattly exhaust... only happens when i accelerate though.. what if i keep ridin' on the bad wheel bearing?
Old Aug 25, 2003 | 06:20 PM
SuperChris's Avatar
Infiniti 35 Double G's
betcha a nickel it's your bearings...you're describing the same sound my wheels are making in the rear, typically any speed above 20mph. does the sound get quieter when you make a sharp turn at speed, like on a highway ramp?
i think both my rear wheels' bearings are toast; gonna get 'em fixed tomorrow.
Old Aug 26, 2003 | 09:38 AM
Thaniel's Avatar
The way I found my bearings were the problem was to remove the tire and the caliper. Stick the tire back on then spin it. It would make a sound every rotation or two. Wasn't every rotation. Kind of weird. Not what I expected. The bearings are not standard though. You can't replace only the bearings. Have to replace the entire hub. Does make it easy but more expensive. Seems like it was $80-90 for the hub. Did eliminate the noise and the car drives oh so quiet.
Driving with bad bearings isn't a good thing. Eventually they could lock up or come off.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
