5-spd transmission problem, synchronizers?
Old Aug 18, 2003 | 10:23 AM
norton2099's Avatar
This problem is sort of difficult to explain, but here goes. I don't know exactly when it happened but now when I try to shift into second gear it would grind even with the clutch in. The 'gate' which stops you from putting the transmission in any gear doesn't exist on the second gear. I was wondering if anyone had a similar problem. I'm thinking this calls for the transmission to be taken apart, how much do you think this will cost?
Old Aug 18, 2003 | 01:54 PM
Jason R's Avatar
aka UNCDooD
i spent about $400 in just parts when my 3rd gear syncros went bad last month. I had mine done by a friend on the side so I only paid $100 for labor which included dropping the tranny fixing it and putting the tranny back in. good luck on getting it fixed.
Old Aug 18, 2003 | 05:23 PM
sryth's Avatar
Can you shift fine if you rev match?
norton2099's Avatar
Thanks a lot, hopefully nothing else is damaged inside the transmission. Car problems always seem to come at the most inopportune times for me. =[
Old Aug 18, 2003 | 05:53 PM
Nismo's Avatar
same here but I think its because theres the wrong fluid in there. redline goes in in a couple days, hope that helps
Old Aug 21, 2003 | 02:06 AM
norton2099's Avatar
sryth-
If I rev match it goes in pretty well with a little bit of grinding, I'm taking it in tomorrow to crack the transmission open.
Nismo-
After I put in redline it shifted a heck of a lot smoother
Old Aug 21, 2003 | 12:06 PM
sryth's Avatar
Sounds like your syncro is gone. You might have other problems (not sure about the gate), but yeah...basically the tranny needs to come out a be split in half to proceed any further.
If you don't mind potentially wasting money, try the redline. I have a feeling you could save yourself the trouble and just hand it to the recycling center
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
