NEED HELP - removed stock intake system unsure about sensor
Old Aug 19, 2003 | 05:37 PM
driver824's Avatar
i know that if u remove the stock intake on the pipe goin to the airbox there is a sensor. im just not sure what to do with it now and how to get rid of the service light. i know this is stupid but , i did it because i always wanted to and have seen plenty of peiple with out it. so.. what now??? thanks for the help.
blake
Old Aug 19, 2003 | 06:04 PM
nadir_s's Avatar
vicodin ... gift of life
hmmmm
well if you're talking about the MAF sensor, then that definately needs to be plugged in. If you didn't disconnect your battery before taking your intake apart, then you will probably have to connect the sensor back... disconnect the battery, wait some time (maybe a couple hours) and reconnect the battery and hope that resetted the ECU.
I'd recommend putting the intake back if you don't know what you're doing...
Old Aug 19, 2003 | 06:13 PM
WhiskeyJack's Avatar
If you're talking about the temperature sensor (looks like a resistor in a 'u' shaped plastic piece) then just zip tie it somewhere handy, do the same with the 'other' sensor (boost?). For the MAF sensor you must disconnect the battery then reinstall the sensor in its receptacle, then reset your ECU. Get those instructions online or look in your Haynes manual.
Cheers,
Matt
Old Aug 19, 2003 | 06:22 PM
driver824's Avatar
ok im not sure if were on the same page. the stock airbox has a tupe that begins right above the front grill. the tube then runs to the lower airbox. in htis tube there is a sensor. wht is it and what does it do???
Old Aug 19, 2003 | 07:02 PM
nadir_s's Avatar
o haha, well removing that really doesn't help you... maybe make it look like you have more space.
I think yo can just leave the sensor there... isn't it attached to that metal bracket?
Old Aug 19, 2003 | 07:30 PM
sryth's Avatar
That's the boost sensor. It detects atmospheric pressure. Just zip-tie it somewhere (mine's tied to my battery cable)
Old Aug 19, 2003 | 08:12 PM
driver824's Avatar
well the reason why i crazy doin this was b/c im getting my injen CAI in a couple of days. i need to make room for the pipes.
Old Aug 19, 2003 | 08:52 PM
sryth's Avatar
So you're removing the pipes now? Is the Maxima your 2nd car?
Old Aug 19, 2003 | 10:28 PM
maxima_se007's Avatar
mine is zip tied and everything is working great. I just zip tied to the other wires next to it. Or maybe it was the little metal bracket that holds the connectors. i forget, just pick a spot.
Old Aug 19, 2003 | 10:40 PM
driver824's Avatar
what u talkin about??
Old Aug 19, 2003 | 10:45 PM
sryth's Avatar
I don't understand this statement. You're getting the injen CAI in a few days...you're making room for it now?
Old Aug 20, 2003 | 12:24 AM
driver824's Avatar
i was bored and i wanted to get the stuff out. so th install would be easier. i just but the stock tubing back in and hooked up the sensor back up.. but now i cant get the service engine soon light to turn off.. how do i do that???
Old Aug 20, 2003 | 01:38 AM
sryth's Avatar
That sensor should not trip the CEL. Did you start your car w/o the MAF sensor plugged in? Is your MAF sensor plugged in now?
Not right to tell a "Maxima Fanatic" this, but read the stickies!!!
Matt93SE
May 24, 2019 02:58 PM
95Maxi
Aug 29, 2015 09:38 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Maxboy23
Aug 21, 2015 11:02 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
