02 sensor change = hella difference
Old Aug 19, 2003 | 11:45 PM
meccanoble's Avatar
Sports Button FTW
recently, my car has been feeling real sluggish. If i get out of first gear normally, i get a little jumpy coming out and normally have to put more gas to get a descent/good start. My gas mileage was real bad and the car driving just felt real sh*tty on first and second gear...the rest were ok...
I also got an 03 03 code and resetted my ecu. Code went away but that was the second time in like a month and a half that i got some type of 02 sensor code so i decided to change...
=======front 02 sensor changed=============
Car comes out the block a lot faster and smoother. Shifting brings out more power and is a lot smoother. I'm very pleased with the difference, and as far as gas mileage, i cant really say but i've been gunning it a lot and gas is still in same spot. Everyone make sure u check your 02 sensors when car drives kind of ugly. It does make a big difference...
Old Aug 19, 2003 | 11:49 PM
maxima_se007's Avatar
thanks i'll look into that. kind of off and on sluggishness for me, but my symptoms kinda sound like a bad ks. If not, i'll try the o2's though.
Old Aug 20, 2003 | 06:18 AM
95CustomMaxima's Avatar
Where did you buy your oxygen sensor from and how much?
Old Aug 20, 2003 | 06:38 AM
happyricefob's Avatar
V^___^V
Re: 02 sensor change = hella difference
give ur ECU some time to adjust to ur new O2. my gas mileage didn't get better until the 3rd tank of gas after the new O2 and knock.
good luck.
Old Aug 21, 2003 | 10:31 AM
meccanoble's Avatar
Sports Button FTW
Re: Re: 02 sensor change = hella difference
good luck.
hmmm, might just reset ecu, but i've been driving hard with the needle just over the E line for the past 1 and a half days and my gas mileage looks a lot better. Cant wait to put a full tank in but this gas seems to last forever...normally i would have to put more gas in to go to work but i took that gas i had to work and back with heavy revving and some more...
Old Sep 16, 2003 | 05:28 PM
munji's Avatar
I am in dire need of one too, could you tell me the best priced site??
Old Sep 17, 2003 | 09:34 AM
maxNYC's Avatar
i second that... o2 site plz
Old Sep 17, 2003 | 09:55 AM
Kevin Wong's Avatar
I get the 0505 code, but I swear something is up with my Knock and o2 sensors. I have 68K miles on the original sensors and my stock cat fouled out. I just need some free time to work on my max.
Old Sep 17, 2003 | 10:21 AM
DoGGy
SAME FOOKING **** HERE BRO
CEL has been on for a week and it keeps giving me 0505. im taking it to stealership today and see wtf they say.
Old Sep 17, 2003 | 11:02 AM
mzmtg's Avatar
Minister of Silly Walks
www.buyoxygensensors.com
Old Sep 17, 2003 | 11:58 AM
maxNYC's Avatar
Originally Posted by mzmtg
thanks for the reference, mzmtg
Old Sep 17, 2003 | 12:01 PM
Cutler's Avatar
Change all 02 sensors when one fails, that way no more worry!!!!
Old Sep 17, 2003 | 01:26 PM
joew's Avatar
Curious, how many O2 sensor are there through out the car?
Old Sep 17, 2003 | 02:04 PM
bignick's Avatar
There's three - 2 on the y-pipe and one on (95-96) or after (97-99) the cat.
I just ordered all three from buyoxygensensors.com, since I randomly get all 3 codes (front left/right and rear) every few weeks. Total was $190 (for the OEM plugin sensors, no splicing connectors) which isn't bad at all. I'll probably make up that much in the amount of gas I'm saving ($2.05 a gallon in NYC!) a year.
Nick
Old Sep 17, 2003 | 07:44 PM
joew's Avatar
bignick thanks.
Old Sep 17, 2003 | 07:50 PM
Maximum96's Avatar
will it be the same if we get the universal sensors?
Old Sep 17, 2003 | 08:22 PM
97GLES's Avatar
i was told by my local dealer to change the KS at 60k mls. they always go bad.
Old Sep 18, 2003 | 04:10 AM
maxNYC's Avatar
i have 58k and my knock sensor just went as well. I'll be replacing the o2s as well. I heard to stick with OEM ones.
anyone have experiences using the "walker", denso and NTK brands?
Old Sep 18, 2003 | 05:02 AM
PolarisGT's Avatar
Any one has posted a writeup on how to change O2 sensors yet? May need to change mine as well. Mine has 96K on it.
Old Sep 18, 2003 | 05:26 AM
Sprint's Avatar
yes i have posted it many times
but since no one likes to use the search function
http://forums.maxima.org/showthread.php?t=207681
Old Sep 18, 2003 | 06:47 AM
astil's Avatar
o2 sensors
I had a code 1001 (o 2 sensor heater) and measured them as per Haynes manual .Both front sensors had the same heater resistance. I just played with the connectors (connected -disconnected) a few times,and actually the code disappeared. So far for 2 weeks no more code ( the CEL light never on).The car has 137 k (96 se 5 sp) , and the sensors are Nissan sensors ,and they are pretty rusty. Got the car with 130 k on, and have no ideea if they were ever replaced. I have no code at this point,so not sure if I should replace them at this point or not.The car feels a bit slower than it used to be,and already replaced the KS (even the KS WAS still good). Any input is appreciated.
Old Sep 18, 2003 | 01:36 PM
CullenJ76's Avatar
four on a cali spec.
Old Sep 18, 2003 | 03:20 PM
nadir_s's Avatar
vicodin ... gift of life
glad to hear ure car is better!
Old Sep 18, 2003 | 03:36 PM
seegarman's Avatar
Any one have comments? I'm ready to replace my O2 sensors too.
Who supplies the oem sensors to Nissan anyway?
Old Sep 18, 2003 | 06:59 PM
CullenJ76's Avatar
i think it is BOSCH
Old Sep 19, 2003 | 07:36 AM
seegarman's Avatar
Originally Posted by CullenJ76
i think it is BOSCH
You may be right about Bosch.
I'm guessing that the supplier may be a Japanese one since their business model is to form relationships and buy domestic products to keep the local economy going.
Any more ideas?
Old Sep 19, 2003 | 08:32 AM
maxNYC's Avatar
i heard bad things about the aftermarket bosch o2's from two other mechanics.
Just Looking for recommendations on reliable o2's replacements that were used.. . thx
Old Sep 19, 2003 | 11:30 AM
BluFlame's Avatar
I think nissan uses NGK/NTK brand oem sensors.
I changed my knock sensor eventhough I got no CEL, plastic casing around the sensor was cracked, now I can chirp tires: case closed.
Old Sep 19, 2003 | 11:34 AM
maxNYC's Avatar
Yep, i just changed my knock sensor as well. O2's are next.
I guess my y pipe upgrade will just have to wait a bit longer
Old Sep 19, 2003 | 07:21 PM
tm96max's Avatar
Hey guys,
Another good place to check is sparkplugs.com, I just bought from one from there. Prices are good and they shipped fast.
Troy
Old Sep 19, 2003 | 09:26 PM
turbolaw99's Avatar
Any suggestion to remove the front bank O2 sensor that's stuck and has been stripped/damaged by the O2 socket? Thanks.
Old Sep 20, 2003 | 09:11 AM
PoePoe2797's Avatar
Try getting at it with a vice grip if you can reach it. If not, its time to pull off your Y-pipe
Old Oct 6, 2003 | 10:28 PM
hoodedmunkee's Avatar
buyoxygensensors.com doesnt seem to work for me
Old May 19, 2009 | 08:15 AM
downwitda's Avatar
Originally Posted by tm96max
Hey guys,
Troy
I second that; ordered 2 front Denso OE replacement sensors from SparkPlugs.com, got a 10% Maxima.org discount, and got them three days later (from CA to FL, cheapest shipping option) for a total of $107.81. The sensors' base price was $55.48 each, and these were the "super class" sensors, which were on sale at the time.
Our moderators/admins are working with the Sparkplugs.com representatives to make them an official .org sponsor, or at least to get us some more significant group deals.
Old May 19, 2009 | 02:15 PM
mahanddeem's Avatar
I changed a bad O2 sensor (the one CEL was throwing code of)...shty,not even a change in anything (no performance , no MRG increase)..lol,don't get fooled by that little stupid O2 boy....!!
kjlouis
Nov 24, 2018 06:09 AM
maximusrising
Sep 2, 2015 09:55 AM
Maxboy23
Aug 21, 2015 11:02 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
