Changing White Se faces?
Old Aug 21, 2003 | 05:08 PM
Flava_24/7's Avatar
Boosted Panda
Is it possible to swap my White SE gauge faces with the black faces of another cluster? My gauges are acting up and its cheaper to buy the black cluster then the white ones so I was wondering if I could just change over the faces.
Old Aug 21, 2003 | 05:39 PM
MIXXMAX's Avatar
Re: Changing White Se faces?
You can change over the faces, but you'll need another cluster as well, because Nissan only sells the assembly for each gauge independently, which makes it more of an expensive replacement. Your best bet is to just get a cluster close in mileage to yours and do a direct swap. To change the faces only, the needles need to be removed and recalibrated when reinstalling the faces. Taking this route, though, you run into the risk of miscalibration of your needles, which will cause more frustration!
RWCreative
Sep 21, 2015 11:01 AM
meccanj98
Sep 16, 2015 06:06 PM
minsbang
Sep 11, 2015 08:48 PM
doctorpullit
Sep 10, 2015 06:33 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
