quick knock sensor questions
Old Aug 22, 2003 | 10:33 AM
dpassino's Avatar
How do i know if I have bad knock sensors?
How much for replacements and where do I get them?
Are they easy to install?
Oh, i have 1999 se Cali Spec
Old Aug 22, 2003 | 10:36 AM
97blackSE's Avatar
1)you only have ONE knock sensor...You will have a Code but NO CEL...0304
2)$80-$100 +shipping off ebay...MAKE SURE THEY'RE NEW
3)Yes, If you have the right tools, or like Bloody knuckles
Old Aug 22, 2003 | 10:49 AM
Jatan's Avatar
2)800-100 +shipping off ebay...MAKE SURE THEY'RE NEW
$800??? You must be crazy Adding an extra 0 will confuse the poor guy.
They'll go for $90+ shipped on eBay (about $50+ for a used one).
http://www.skippynet.com/maxima/knocksensor.htm
http://www.motorvate.ca/mvp.php/507
Old Aug 22, 2003 | 10:54 AM
97blackSE's Avatar
edited
Old Aug 22, 2003 | 03:53 PM
dpassino's Avatar
one last question then.. lol
I am a stupid noob...
what do i need to check the codes?
Old Aug 22, 2003 | 04:01 PM
gansemer's Avatar
A screwdriver.
The ECU is located behind the center console on the drivers side (right next to the gas peddle) Remove the plastic trim panel and peel back the piece of tape covering the screw on the side of the ECU. With the ignition in the "ON" position, turn the screw all the way clockwise, wait 5 seconds, turn the screw all the way counterclockwise and the check engine light will flash out the codes. The first number is indicated by long flashes, there will be a 2 second pause and the second number will be flashed out in shorter flashes. Example 3 long flashes, pause, 4 short flashes = 0304 (knock sensor fault). If there are two or more codes in the ECU, they will be flashed out in sequence, then the whole series will repeat. Remember: 1 number long flashes, second number: short flashes.
Old Aug 23, 2003 | 03:20 PM
dpassino's Avatar
Originally posted by gansemer
A screwdriver.
thanks dude!
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Slamrod
Sep 3, 2015 07:38 PM
soloist3
29
Sep 1, 2015 03:47 PM
maxinout93
Aug 20, 2015 02:17 AM
