What exactly is a knock sensor?
Old Aug 25, 2003 | 03:45 PM
SaNdMaN's Avatar
What exactly does a knock sensor do? And why would you need to replace it?
bobjohnson's Avatar
Blazin......
its junk. thats all i know.
Old Aug 25, 2003 | 03:46 PM
willis's Avatar
My heroine
Re: What exactly is a knock sensor?
faq.. read it.. it's a quite amazing thread up there at the top.
Old Aug 25, 2003 | 03:58 PM
SaNdMaN's Avatar
couldn't find it in faq
Old Aug 25, 2003 | 05:40 PM
gansemer's Avatar
A knock sensor detects when the combustion mixture in cylinder is igniting before the spark fires (begining at a place other then the spark plug electrode) This is called pre-ignition. The knock that you may or may not hear is the multiple combustion fronts colliding and causing various engine parts to resonate. This is bad for your engine and can destroy it very quickly (although I had an 81 Volvo that knocked badly from when i hit 200,000 miles until I sold it at 250,000 miles). By using higher octane gasoline, the knock can be eliminated since the higher octane reduces the tendency to ignite. Cars that use high compression ratios, such as your Maxima, use higher octane gas (91+) to keep knock from happening.
The knock sensor listens to the engine to detect knock as early as possible and change engine operating characteristics to try to eliminate it. It does this by retarding the ignition timing. I believe a Maxima has ignition set at up to 18 degrees before top dead center under acceleration and 0 degrees at cruising speed (low engine load). If you have a bad KS, the Maxima always sets the timing to zero degrees to minimize the chances of pre-ignition since it no longer has its ears to go by. The bad news is that engine performance is inhibited (loss of low end power) as a result.
If you are using 91+ octane gas, you should not experience knock. If you are driving around with a bad KS, you will loose performance, but the engine will be protected (you may experience a loss in mileage). If your ECU is throwing a KS code and you want to get back to maximum performance, change your knock sensor.
Old Aug 25, 2003 | 06:11 PM
SaNdMaN's Avatar
got it, thanx
Old Aug 25, 2003 | 06:20 PM
willis's Avatar
My heroine
3rd to last post in the faq.. the real friggin long one
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
