What problems to look for when there is a oil leak?
Old Aug 26, 2003 | 04:56 AM
Grey00lustre's Avatar
i was wondering has anybody have oil leak on their cars and what problems was associated with it? last time when i was at the dealer they mention like the oil pan gasket....any suggestion would be appreciated...
Old Aug 26, 2003 | 05:53 AM
maximaseefu's Avatar
you can check the gasket or around the plug in next to your oil filter. forget what it's called. can't you look under the car and see where the leak is coming from?
Old Aug 26, 2003 | 05:58 AM
big_al's Avatar
Oil pressure sending unit.
Old Aug 26, 2003 | 06:10 AM
thanks. it's too early in the morning. not thinking yet.
Old Aug 26, 2003 | 12:54 PM
what if it's the gasket near the timing chain near the power steering? is this a costly to fix?
Old Aug 28, 2003 | 10:06 AM
jguillory's Avatar
I just had to have the timing cover gaskets replaced due to an oil leak; VERY time consuming and expensive.
Approximately 15 hours of labor becuase everything in the front of the engine compartment (passenger side of the car) needs to be disassembled. Parts were about $30 because there are actually several seals needed. Total job (unfortunately at Nissan dealer) was almost $1400. Sucks.
Old Aug 28, 2003 | 12:06 PM
kman3k1's Avatar
Yeah, I had that same problem with my max. Except at first they thought it was the upper oil pan gasket, so they replaced that. My car still leaked oil, so they decided it was the timing cover gaskets. It is a very time consuming job, and expensive unless you find a mechanic that doesn't know how much work it really is. (I found some guy from a chevy dealer to do it on the side for $250, He got screwed )
Good Luck
Old Aug 28, 2003 | 01:57 PM
thanks for all your advise...i had the car check out today they told i need to replace the lower oil and oil pressure sending unit...i hope this is right and not the timing cover gasket which i know is expensive...
captchaos
Mar 15, 2016 12:18 PM
kjlouis
Oct 3, 2015 05:29 AM
markevans999
Sep 10, 2015 04:29 PM
dcam0326
Sep 7, 2015 07:26 AM
nbstriker10
Sep 4, 2015 04:26 PM
