Help! Rear brake caliper problem.
Old Aug 26, 2003 | 10:34 AM
sup94tt's Avatar
I was changing the rear brake pads on my 1998 Maxima, after removing
the calipers, the piston would push back in. So, I am thinking the caliper is seized. But, when I press the brakes the rotor does not
turn. Has anyone else had this problem?
Old Aug 26, 2003 | 12:26 PM
largestal's Avatar
"the piston would push back in.....caliper is seized"
huh?
Old Aug 26, 2003 | 01:11 PM
hacim105's Avatar
Re: Help! Rear brake caliper problem.
The back pistons are not pushed in, you have to twist them to make them go in. You can use needle nose pliers to do the job but it's difficult. Easiest way would be to go to an auto store and ask for the part used to compress the rear brake pistons.
Old Aug 27, 2003 | 08:24 AM
sup94tt's Avatar
Thanks for the info. I was about to order new rear calipers.
Old Aug 27, 2003 | 08:26 AM
Scruit's Avatar
U wanna try me young boy?
You cannot poress them in - they must be rotated back. Get the tool from your auto parts store - like $5.
rbuswell
Nov 17, 2016 04:54 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
