Radiator Support Removal/Installation
Old Sep 1, 2003 | 09:18 PM
PoePoe2797's Avatar
What is involved in removing and installing the radiator support. I have a bad crack next to the centermember that threatens the engine and I have access to one for about 100 new. Is there any welding involved with putting in a new one or is it just bolts? Thanks
Old Sep 2, 2003 | 07:59 AM
JdawgX's Avatar
As far as I know it's a lot of welding. mine had to be replaced when i hit a deer about a year ago and if i remember right, it had to be welded in. I could be wrong though. i had a lot to look at with that $8000 worth of damage!
Old Sep 2, 2003 | 08:16 AM
nupe500's Avatar
Jedi Knight
if you're referring to the lower radiator support...it would definately have to be welded on. The radiator is easy to remove. Remove the two 10mm buts up top and disconnect the cooling lines and the wiring harness and pull up. Presto..done deal
Old Sep 2, 2003 | 01:00 PM
PoePoe2797's Avatar
Yup, the lower radiator support...how much would a shop want for that?
Old Sep 2, 2003 | 01:41 PM
nupe500's Avatar
Jedi Knight
dunno...it would involve removing the one there...and welding the new one. go and ask
Old Sep 8, 2003 | 09:07 PM
18its's Avatar
i think i might have the same problem! after washing my car and wiping underneath, i noticed the centermember was cracked from its frame and i don't know if this is something i can ride on for a while... should i be concerned about this and take action immediately, or can i drive with this for a while until i can rack up some money to have this replace and fixed?! so far my car is running stellar and i'm not having any problems, but, what kind of estimate am i looking at if i get this fixed?! thanks for your feedback. life-long max owner
Old Sep 9, 2003 | 07:24 AM
PoePoe2797's Avatar
Ok, I took some pics...quite large, the first one is really good. I was told it's the radiator support. Bad eh?
Old Sep 9, 2003 | 06:12 PM
PoePoe2797's Avatar
To the top
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Turbonut
46
Oct 21, 2015 08:28 PM
Hdnseek
Sep 9, 2015 05:55 AM
