loud brake screeching
Old Sep 6, 2003 | 09:07 PM
blkhawk500's Avatar
There's a very loud screeching noise whenever I softly press on my brakes. If I brake hard, there is no noise. It sounds similiar to when a truck slows down to a stop and is veryyy annoying, especially in slow moving traffic.
The rear pads are fairly new (not sure of the brand) and the front pads are less than a month old (I think they're called "metalizers", from autozone)
Any ideas as to what might be causing this noise?
PS: If the car has been sitting for a while, the first couple of stops there is no noise untill the pads and rotors heat up.
Old Sep 7, 2003 | 12:12 AM
Beldin's Avatar
Fat Kid
Your rotors may need to be turned. This happened to me when I first got my max.
Old Sep 7, 2003 | 06:10 AM
njmaxseltd's Avatar
If your brake hardware is not holding the pads securely, they squeal. You can buy a new shim kit from Nissan and replace all the hardware. That should quiet them down. If one or more of the pads still sits loosely on the mount, you can shim it slightly.
Old Sep 7, 2003 | 07:13 AM
blkhawk500's Avatar
thankx for the info....but what do u mean by turning the rotors?....(sorry im new)
Old Sep 7, 2003 | 10:41 AM
bananamax's Avatar
Turning the rotors is when a machine shop uses a lathe to remove a small amount of surface material. This accomplishes 2 things:
1. Removes any surface imperfections due to uneven wear.
2. "trues" them- makes them perfectly round and flat.
I'm guessing, though, that the main cause of the squealing is due to a loose pad. Where did you get the brakes done in the first place? They may have fouled up a shim, or short-changed you on the anti-squeal compound.
Good luck!
Old Sep 7, 2003 | 11:52 AM
blkhawk500's Avatar
I just bought the car and the previous owner changed them (i dont know where) ...where excatly do you put the compound?
Thankx for you help!!!
Old Sep 7, 2003 | 05:08 PM
bananamax's Avatar
it goes between the shim and the pad backing, and also between the caliper and the shim. The compound is simply a very viscous grease. Tear it apart and take a look. If it is dry, smear a little on.
Keep us posted!
Old Sep 7, 2003 | 05:56 PM
ivelweyz
He means to get them resurfaced...
Old Sep 7, 2003 | 06:08 PM
SXN's Avatar
SXN
could it be the wear tab on the pads making noise telling him to change them? just an idea
Old Sep 7, 2003 | 07:01 PM
Beldin's Avatar
Fat Kid
He said they were just replaced.
Old Sep 7, 2003 | 08:09 PM
Jatan's Avatar
There might be some TSB's at AllData.com. I know there are a few braking ones for my 95.
My brakes make crazy noise and people always look at me whenever I hit the brakes. Going to get the shim kit for front and back when I get money for new pads and rotors.
Old Sep 9, 2003 | 09:48 PM
SXN's Avatar
SXN
oh well...i missed that
Old Sep 9, 2003 | 11:14 PM
ThurzNite's Avatar
But his symptoms sound like my symptoms. My wear indicator was making noises only when I brake lightly. When I brake hard, no noise.
I changed my front pads today. Sure enuf, warning tab was rubbing only when brakes are applied. When braking heavily, the warning thing bends in such a way that it doesn't produce audible sounds.
Jae
Old Sep 9, 2003 | 11:20 PM
SXN's Avatar
SXN
so maybe i am right? lol
Old Oct 30, 2003 | 08:23 PM
blkhawk500's Avatar
I finally solved the problem of the screeching. I was the pads. I changed them to a carbon metallic type pad and now there is no squeking. There is a slight sound under heavy braking but that's music to my ears compared to before.
thankx to all that replied
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
