Transmission Problem Please Help :-((
I am new to these forums, so please, take it easy on me. I've been a maxima fan ever since the 3rd generation. I currently have the 4th generation Maxima. It's a 1998 SE fully loaded. I've had the car from 0 miles, and I am the original owner. Service was completed as were set in the service manual, and everything was smooth until this weekend. When changing my oil my mechanic told me that my transmission oil was leaking, without a doubt I thought it was the axle seal. When he opened the axle, I was horrified of the news; it was my differential bearing that is bad. Reading some of the forums here it looks like that the 4th Generation is infamous for these problems. I also found out that my push bearing will need to be replaced because every time I start my car there is a growling noise, and when I push down the clutch it goes away. Now, this is where I run into a dilemma. My car has 110,000 miles and rebuilding mine would be costly ($1100) and absurd. I found a transmission for $1000 that is locking (LSD) with 23K original miles, coming from a 98 Maxima, and I can have the mechanic put it in for about $250. Should I go ahead and replace this transmission with the used one, or should I get a remanufactured one? Also a lot of people at this forum posted that originally Nissan didn't shim correctly the stock bearings, and they turned out to be too big, by 6.4 thousandths of an inch if I am not mistaken. If I buy this transmission will it go bad on me at around 60K because of the same bad problem, that being the bearings, or should I just go out and get a remanufactured one? (Quoted for $1100) Also how long can I drive this car, I drive around 2,000K a month, and the oil keeps on leaking more and more each day. It is at the point where I noticed the smell. When in gear; the 1st 2nd and partially 3rd gear make a dull whining noise, I think it’s because of the low oil in the transmission-- maybe I am wrong. If I drive like this what's the worst that could happen to the car? Lastly, since I will probably be replacing the transmission, I am going to put in a new clutch. The one I found is Exedy clutch kit; I am able to get it for $132. Is that a fairly descent price, and is there a better one for a little more money? I know that I have exhausted you already, but I would greatly appreciate some feedback to this post. My gratitude goes out in advance. If anyone is familiar with these questions/problems PLEASE post them here or e-mail me @ staplescomp@aol.com
So instead of spending 1100 on rebuilding his own tranny, he'll spend 1000 in buying a used one AND spend 1100 on reshimming it? You obviously never rebuilt a maxima tranny.
(The diff shims are the very last component out of the case - so it would be exactly the same amount of labor as a full rebuild.
I pulled the tranny myself and brought it to a Transmission Shop. It should only take a couple hours at the most for a good transmission guy to do the job if he just has the transmission and doesn't have to do all the work to take it out of the car. I only payed 200 bucks, and that includes the bearings.
Originally Posted by ivelweyz
hell no, get the LSD and tell the mechanic to fix the shim proble...
1100 for rebuilt or 1000 for used? I'd rebuild - and make sure that include all 6 bearings and checking/adjusting endplay on bith input and main shafts plus diff housing.
The bearings for a VSLD tranny are almost twice as much as a non-locking tranny.
Well, you tell us what you want to do? Do you have the money to spend, or do you just need to fix it so you have a "working" vehicle. I say, if you money, get the VLSD tranny. When it arrives, immediately take it to a shop and have them re-build it. Since they only have to "re-shim" it, it should be in the neighborhood of $500.00, that is what a local shop wanted around here when I was looking into rebuilding my old 5-speed. So, you will be spending about $1600-$2000 for the VLSD tranny, labor to re-shim it, new bearings/shims, and labor for the other shop to put it in. And, just to let you know, they can't just do this project in one day. Once they find the bearing load of the differential, they need to order the shims from Nissan, which took me about 7 business days, but that was my situation, not yours.
If you do get the VLSD, don't just slap it in there. Because no matter what in the future, the differential bearings will go bad. So why not jsut do it now and solve the problem from square one? I hope this clarified a few things for you.
Originally Posted by BLCKMAX
O.K I just found a 1998 transmission w/38K miles for about $500. In my opinion, I mean I don't know that much, 38K miles on a transmission is not all that much, why would I need to reshim it and put new bearings? Doesn't it have very little miles and by theory should last me another 100k miles? Should I really be rebuilding this tranny? The guy that I am buying this off also tells me that these tranny's go for like 150K-200K without the problems of bad diff bearings? and lastly is this true or not?
Originally Posted by Altimat
Where did you find it? It looks like I need one for my '96 SE also. I have a "card in spokes" type noise most evident under acceleration in lower gears, but still audible in neutral. It goes away when the clutch pedal is depressed. Is this the "push" bearing? Can anyone recommend some good used parts sources?
dont just expect a trans that has low miles not to have problems a different bearing problem will be evident around 60k miles, while that new used trans it out have it checked and make sure that ther bearings are okay, then u can have some piece of mind
and if it needs repair maybe 200-400 since the trans is out
nope i haven't had any bearing problems after 103k, it would show wear at 40 k, but it would get noisy at like 60 k in first gear especially, and slowly creeping into second gear
if its bad they'll know, just make sure they do a thorough internal trans inspection, when the bearings are going you will hear a whining noise in ur transmission that will slowly creep into the higher gears starting from first gear (not to be mistake for the whine heard when reversing or accelerating in first gear)
My tranny broke recently and I was in the same boat as you (sorta'). I was going to go with a used or remanufactured tranny, but the Nissan dealership told me that all 5-spd trannys that they can get are brand new in a crate. I would NOT recommend a used one because you never know what that has been through.
Spend a few hundred more... get it done at a Nissan dealership... get a brand new tranny as a result. It is well worth it. You will also get the warranty on the NEW tranny, and labour.
Good luck.
Good luck.
Good luck.
Good luck.
how much did this cost?
Good luck.
Good luck.
Prices in Canadian $:
Brand new 5-spd tranny in crate: $2200 CDN
Labour: $399 CDN (I got quoted $500... nice to see honest dealerships once in a while)
Total: just over $3000 CDN after taxes
Self imposed expenses
:ACT stage 1 clutch + UR flywheel: $780 US
Thnx for the suggestion
But I bought a tranny from a 98 Se w/ LSD with 43K for 500$ the dealer wanted $2000 plus 1000 for labor. I am paying 250 for labor, so what I will do is basically have them inspect the old tranny make sure the bearings are good and hopefully with some luck it will work
Good luck again and hope you get your car back soon.
rememeber you will need a LSD driver side axle as well with the LSD transmission
$500 is hard to argue with, to justify spending almost 3x that for a brand new tranny. I hope that your tranny problems are worked out... if they are offering to rip open your old tranny and fix it, just for $250 in labour that is awesome!
yea thnx speed. It is costing me 250 for them to take it out and put it in. PLUS I ordered a BRAND new clutch so the guy is putting in for me for free
I have an SE I thought that they could just swap it out and replace it
Don't forget, axles are not cheap... you'd be paying another $150 for each axle (dealer price I think).
Not unless you already have LSD. The dealership told me that they would order both axles because there is a possibility that both will need to be replaced... plus there might be other parts too.
you DO have lsd? then its no problem
100 to look at the bearings is fair enough, i payed friggin 300 for diagnostic and dropping of the trans so... yeah
100 to look at the bearings is fair enough, i payed friggin 300 for diagnostic and dropping of the trans so... yeahThread
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
