Levoc Shifter Install...easy/hard?
Old Sep 10, 2003 | 05:17 PM
SuperChris's Avatar
Infiniti 35 Double G's
Just trying to find out what's involved with installing this shift lever before I buy it. Anyone who has this, what's needed for install?
Old Sep 10, 2003 | 06:09 PM
Jepht20's Avatar
Custom User Title...
take off stock... cut o/d wire. splice new wires for new shifter. stick in and screw down.
i have a different one but they are installed the same. overall not too bad. had a friend help me do it. if you're comfortable cutting and splicing wires, you should be fine.
Old Sep 10, 2003 | 06:52 PM
Nismotic's Avatar
Always sunny in philly
piece of cake. It'll take you 10 mins. Hard part is just ...unscrewing everything
Old Sep 10, 2003 | 07:19 PM
Parsec's Avatar
it's not good to mislead people with quick times. if you've never done anything like this before, leave a good 45 min. it actually took me 1.5 hrs when i did it on my altima cuz the OD wires were so short and i had one of those stupid universal wire cutter/crimpers that wouldn't fit in the tight space.
Old Sep 10, 2003 | 08:06 PM
Bgohan's Avatar
The one you have shown is sitting lower than usual. The Levoc **** higher than this installed, unless you cut the shifter post down about an inch or so.
Old Sep 10, 2003 | 08:53 PM
97GLES's Avatar
i installed one in my cuz max and it took me about 35mins and we made it shorter.
i used a small pipe cutter.
Old Sep 10, 2003 | 10:31 PM
Nismotic's Avatar
I guess it was because i've done it on another max before, and it took about 15-20 mins was why i posted it that way. He's right; if you havent done this before, it'll take you longer.
45mins-1hr is about right. best of luck.
Fbana41
Aug 29, 2016 12:18 PM
lux97Max
Sep 28, 2015 11:18 PM
atriuum
Sep 28, 2015 01:19 PM
ef9
Sep 10, 2015 10:35 PM
