Stillen front lip install ?
Old Sep 15, 2003 | 03:35 PM
ohannon7's Avatar
I want to install it myself and know to use 3M double sided tape but do I screw throug it and put nuts and bolts on the corners and middle or what? The shop near here said they add an adhesion spray but they want like $60 to put it on. Id rather save the cash........
Old Sep 15, 2003 | 03:42 PM
maxmic's Avatar
Yeah. Install by yourself. At least you will take most care on the car.
Old Sep 15, 2003 | 05:21 PM
Kevin Wong's Avatar
I used a little 3M tape (cuz I thought I'd remove it soon for repainting) and I drilled two holes through the lip and wheel fender. It's really secure and I have no worries at all of it ever falling off.
Old Sep 15, 2003 | 05:40 PM
97GLES's Avatar
get a buddy to help you, it slides right on.
Old Sep 16, 2003 | 07:41 AM
ZeRo MaX's Avatar
it's easy... do what kenvin wong said.. and it'll never fall off.. i asked.. no one said anythin' bout the lip falling off... :-)
Old Sep 16, 2003 | 09:18 AM
ohannon7's Avatar
So do i use plastic self tapping screws and predrill a smaller hole, or do i drill holes and then put a bolt and nut on to hold it? The interstates here are under heavy construction and theres alot of uneven roads so if it scrapes goin around 80 i dont want it to fly off
Old Sep 16, 2003 | 01:29 PM
maxNYC's Avatar
3m tape and screws at the wheel wells should serve you fine. Just make sure you align it correctly when you mount.
sonic7
Aug 20, 2015 12:23 PM
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
