What do you guys have your KYB AGX's set at? And what kind of suspension do you have? I have Ground Control Coilovers with AGX's set at 3 in the front and 5 in the rear and I find it real bumpy. What should I set them at to reduce the bumps? What do all you guys have yours set at?
Thanks,
-Nick
Thanks,
-Nick
Quote:
Thanks,
-Nick
With the cooler weather, I've been running 1/4. Rides nice!Originally Posted by 95CustomMaxima
What do you guys have your KYB AGX's set at? And what kind of suspension do you have? I have Ground Control Coilovers with AGX's set at 3 in the front and 5 in the rear and I find it real bumpy. What should I set them at to reduce the bumps? What do all you guys have yours set at? Thanks,
-Nick
I run 3/6 with Maxspeeds. I tried 2/4 but it seemed a little bumpy. 3/6 rides much better (more control of the strut).
I'm riding on H&Rs. 2/8 for my AGXs. the highway ride is very solid. i'm making corners @ 110mph w/ no problems. In the city the ride is very firm. I'm thinking about upping the fronts to 3.
I usually run 3/6, and sometimes 4/8. 4/8 is a little much and makes for a harsh ride somewhat. On uneven road surfaces it can make the car sort of hop around corners too. I always use 4/8 for track use though, sometimes I drive around for several weeks with it still on that setting until I feel like a smoother ride. I think with my H&R's 3/6 fits the springs best.
3/6.. But the people sitting in the back complain sometimes. =) 90lb girls go flying when hard bumps are hit. =P
Quote:
1. tell them to gtf out or stop complainingOriginally Posted by ZuMBLe
2. find thicker women
problem solved.
Thanks for your advice. But some of my good friends happen to be 90lb girls. They can't help that. Thanks anyways.
problem solved.
Originally Posted by maxcross
1. tell them to gtf out or stop complaining2. find thicker women
problem solved.
