Continuous 0101 error code
Old Sep 22, 2003 | 09:26 PM
malumax's Avatar
I have been having hard start problems for a long time now. Car will turn well, but not fire..... or it will start to fire and then keep turning..... almost like it is firing at the wrong time.... anyways... I have replaced the coolant temp sensor and camshaft pos sensor, cleaned the TB several times, replaced plugs, fuel filter, knock sensor and alternator. Recently I keep getting the 0101 code... I clear the code and it will come back after a few days after a rough start. I tested the sensor like the haynes says and it comes back okay... anyone have any ideas??.... I have had this starting problem since I turned 38,000 miles.... odo currently reads 116,000. If you need anymore info let me know. Thanks in advance.
Old Sep 23, 2003 | 04:21 AM
njmaxseltd's Avatar
0101 = Upstream oxygen sensor heater or circuit fault (left bank)
Replace your upstream 02 sensor.
Old Sep 23, 2003 | 07:34 AM
astil's Avatar
Actually,that code is not the OXygen sensor...The o2 sensor is 1001 and NOt 0101. If you are looking in the Haynes book,there is a misprint regarding this code (1001) as 0101. The real code 0101 is about a different sensor. I don t remember the exact sensor s name and I don t have the book (haynes)with me ,but if you check the same book ,the real code 0101 is listed there. I am 100 % sure because I had a problem with the o2 heater 2 weeks ago. At this point,I wonder what sensor you cleaned...
Old Sep 23, 2003 | 08:06 AM
maxNYC's Avatar
does the FAQ here define the codes ?
Old Sep 23, 2003 | 10:28 AM
malumax's Avatar
I am working on the assumption that 0101 means Camshaft Position Sensor. I cleaned it a few times/ replaced it once. Still get the code. I havent done anything with the 02 sensors.
Old Sep 23, 2003 | 12:52 PM
astil's Avatar
I wonder if you ve got some problems with the wiring...Idon t see too many posts regarding the camshaft pesition sensor.If you already replaced the sensor,I d look very close to the wiring. In my situation,I had a 1001 code (o2 sensor heater) and the probs I had were in the connector . I connected & disconected maybe 8-10 times,and took a good look at the connectors,make sure that they are not in bad shape. It may or may not work for you, but not too much to loose at this point. You may need to have the dealership connect the Consult to your car...
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
