I rewired my blinkers
Old Sep 23, 2003 | 02:52 AM
PeTeRtheEaTeR's Avatar
I rewired my blinkers so that it alternates and i think it looks great. I had the other mod where the signals stayed on as the headlights were on but i got tired of it so i decided to change it. But i was wondering, and I've been searching too, but i couldn't find anything on having the side marker off while the headlights are on, so that when the headlights are on, only the clearance lights and the headlights are on while the signals and the side markers are off, and when u signal the side marker and the signals blink. (Get it? i know it sounded confusing.) Is there such a mod? I was thinking about cutting the red wire that's attached to the side marker but i didn't wanna do it cuz i was unsure. I'd really appreciate it if someone would help me out. Thanx.
Old Sep 23, 2003 | 04:38 AM
Jatan's Avatar
To have them both off, the only suggestion I got is to take the front turn signal wires and cut them. Then split each wire into 2 wires. Now connect 1 of each back to the front turn signal and connect 1 of each to the sidemark.
I don't know if it'll work, but if it does then it'll both act like the stock setup, instead of just the front one.
Never tried it so I don't know, just a suggestion
Old Sep 23, 2003 | 07:24 AM
Abimax95's Avatar
Hey where did you got the re-wiring how to or how did you make then altenate I'm intrested to make my do the same .......Thanks
Old Sep 23, 2003 | 08:03 AM
mendon11's Avatar
here you go ---> http://www.vqpower.com/v2/modules.ph...howpage&pid=53
this only tells you how to rewire so the blinker stays on though, not for the alternating thing. enjoy
Old Sep 23, 2003 | 09:10 AM
These are the instructions for the alternating blinkers...it's simple and straight forward
http://www.geocities.com/amixam69/nissan/markerblink/
Old Sep 23, 2003 | 12:05 PM
Abimax95's Avatar
thanks guys ....sweeeeeeeeeet....
Old Sep 23, 2003 | 06:10 PM
anyone have any other suggestons that i could do? (read the first post)
Old Sep 24, 2003 | 04:26 PM
bump it up a notch
Old Sep 24, 2003 | 05:19 PM
nismos14's Avatar
§è~® f®ÈÄk
if u want them both on i think u can do it the opposite way with the wiring and just use a higher wattage fuse cuz it will blow out right away when u turn ur lights on or turn signal
Sir Tilus
Mar 22, 2016 01:49 PM
Blackwind
Aug 5, 2015 06:35 PM
Tomo
Nov 27, 2000 06:32 PM
BippuBenji
Nov 15, 2000 08:00 AM
perlmax90
Nov 13, 2000 06:10 PM
