Tie-Rods clunking
Old Sep 23, 2003 | 03:33 PM
95Supra's Avatar
Tie-Rods clunking
I have a 1995 Max with 118,000 miles on it and when I turn the wheel to go in my driveway the front end makes a clunking sound. It's not very loud but, noticable. What price should I expect to pay if the tie-rods are bad?
Old Sep 23, 2003 | 04:37 PM
ChrisA's Avatar
Are you sure its the tie rods?
My '95 makes clunking while turning (especially from a stop, say at a stop sign) and I know for a fact that my CV joint is shot. I just bought it in this condition and its not being driven yet until I change it.
Old Sep 23, 2003 | 06:10 PM
95Supra's Avatar
I pretty sure it's a tie rod. A bad CV joint will make a clicking noise.
Old Sep 23, 2003 | 09:02 PM
JustTry's Avatar
Could also be a bad upper strut mount....my right side was making a popping sound on turns, and it was the mount, so you may wanna check that out.
And yes, CV joints make a click type sound.
Old Sep 24, 2003 | 07:23 AM
astil's Avatar
Just lift the car and support it securely, grab the tire from the bottom and top and see if it moves or not. Next,grab the tire from the front and back and see if it moves or not (should feel movement if the tie rod is bad). You may need to use some force for this test. If you see grease inside wheel well and the inside of the wheel ,your Cv joins may be dead.As in your post,it may be the tie rod if it clunks. They are not hard to replace ,but an alignment would be recomanded after. As for now, your tires may be already bad because the tie rod problem.
Old Sep 24, 2003 | 10:44 AM
mbnickel's Avatar
Control-Arm Bushing(s)? Had that happen on a '95 Nissan P/U a few years back.....
Old Sep 24, 2003 | 11:34 AM
mayhemI30's Avatar
"I'm running with scissors!"
i had the same problem in my 95 se and it turned out to be the lower ball joints. it only is gonna cost me 50 bucks to get them fixed though
Old Sep 24, 2003 | 11:44 AM
2naboy's Avatar
If you are absolutely sure that its your tie rods then might have to replace your whole rach and pinion unless its just the boots that are torn. Replacing the rack and pinion ain't no joke I tried replacing mine and about 1.5 hours later, I turned back and to it to a shop. It took the guy about two hours that day and about 4 hours the next to complete. But mine where both pretty badly beaten up.
Unclejunebug
Apr 2, 2016 05:42 AM
msellas
Sep 23, 2015 09:16 PM
ColdCananda
Sep 20, 2015 10:45 PM
