My autotragic chirps in 2nd gear :)
Old Oct 2, 2003 | 01:45 PM
MaxedOutOfCash's Avatar
Pizda Boy
Just picked up my car yesterday, it was in for a tranny rebuild.
I feel like it has more power and I don't know if this is good or bad but it changes gears from 1st to 2nd really fast (a split second) and it changes it pretty hard. It is so hard that the wheels spin in second gear. . . I kinda like this and I think it'll be better for the track because of the quick shifting, but will it mess up my tranny again??? I don't know if I should go back and have them fix this.
Old Oct 2, 2003 | 02:34 PM
nismos14's Avatar
§è~® f®ÈÄk
haha u might wanna go light on the tranny for a bit, let it break in, yanno? u dont wanna get but by the shop again do ya?? :P
Old Oct 2, 2003 | 03:27 PM
LastBoyScout's Avatar
best way to break it in is to creep up to 170 MPH on that tranny.
besides, after the cops start to chase you, you will get all the up and down shifting you need on those back roads.
Old Oct 2, 2003 | 03:36 PM
VQvroom's Avatar
AUTOTRAGIC?
Dont u mean AUTOMAGIC?
Are you one of those fellas that desires a manual but bought an auto?
Heres my 2 cents. I just got my auto tranny flushed @57k miles. My trans (before the flush) felt like it shifted sorta hard (no chirp) but sorta on the hard side. Now that its flushed it seems to glide into gear. Like a slight slip then engaged. I didnt like it at first but after driving for the past 2 days ive noticed improvements that outweigh that issue.
Old Oct 2, 2003 | 05:22 PM
Pizda Boy
i just got back home. . . cruised around with some friends and they can't believe that it rips so hard into second, how fast it switches gears, and how it chirps. . . i could get used to it. . . but at normal driving it's really annoying. . . anyways i'm going to englishtown on saturday to see how it does on 1/4 mile and i'm dropping it off on monday to get this fixed. . . then i'll see the difference between my times. . .
Old Oct 2, 2003 | 07:52 PM
NOMAD MAXIMA's Avatar
Sounds like you got a valve body upgrade to me. What did you have done exactly? I mean when they asked you what you wanted done did you mentioned that you might race a little every now and then {at the track} or what? I also have an auto trans and want a VB upgrade also torque converter upgrade and the limited slip conversion
with a Phantom Grip. I understand however that
all you discribed is normal with a VB upgrade, unless that's not what you had done.
Old Oct 2, 2003 | 09:23 PM
Pizda Boy
nope. . .didn't have the vb upgrade. . . i think that they just did something wrong or it's getting too much pressure or something. . . i'll see what the problem is on monday. . . but it's annoying to have it jump like that everytime i'm cruising with normal driving. . .
Old Oct 29, 2003 | 08:44 AM
Broaner's Avatar
2060lbs and falling...
Make sure they didn't unplug the tranny resistor for some reason. Its right on the driver's side strut tower area.
Old Oct 29, 2003 | 09:03 AM
meccanoble's Avatar
Sports Button FTW
another reason to come by tonight and see how well your car is shfiting
if u get projectors in your car tonight DEFINITELY call me!
Old Oct 29, 2003 | 11:01 AM
ereet's Avatar
Resistor being unplugged would trigger a CEL. Chirping second in an un-vb'd auto is unheard of, I don't think there's ever been anyone on the .org that had a "stock" auto that would do that. They either built the transmission stronger and better than it's suppose to be, or you're going to be visiting them real soon
Old Oct 29, 2003 | 06:26 PM
Maximum96's Avatar
when i got my tranny rebuilt, it had Some of your same problems, couple days later, it f@!ked up bad and they rebuilt it again, the magnet was full of metal pieces, but it could just be the drop resistor...
Old Oct 30, 2003 | 08:40 AM
carlosr's Avatar
Mine chirped 2nd when I bought it, but had cheap tires on the stock 15's! with 18's now it wont :-(
Old Oct 30, 2003 | 08:52 AM
Pizda Boy
all my friends think i did something to tune it up because it just rippes you out when it changes to 2nd...i'm still waiting for them to fix it.
Old Oct 30, 2003 | 08:55 AM
gabex's Avatar
My auto was chirping from take off, then 1-2... it stopped doing it after I had put some Lucas in my tranny fluid to smooth out the shifting when its cold.
Old Oct 30, 2003 | 05:47 PM
indigomax's Avatar
well...thats not good to me, first dont wot your car after some 1000 miles on the tranny, cause the tranny parts(new ones) will go bad. If you really want to keep your tranny in good cond. Buy a tranny cooler for it. Be sure about the calibrate of the band and your Valve Body too. Nissan has a lot of info about that.
Old Oct 30, 2003 | 09:00 PM
ch13f's Avatar
Even with the drop resistor mod I cant chirp second.. I guess that might be my 235/45/17s but ... Sounds like something isn't quite right
Old Oct 30, 2003 | 09:46 PM
BadKarma99-4spd's Avatar
tires are a big part as well as the type of road you are on. the roads near my house have been repaved and are nice and smooth. when i floor it i lose all traction when i hit secon.
Old Oct 30, 2003 | 10:11 PM
pMB's Avatar
pMB
I agree on the need for transmission fluid change and filter replacement. I did it when I got my car.
It is essential to do these in order to lengthen the happy natural days of automatic transmission. When's the last time you checked tranny fluid? Do you remember the color?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
