EGR Code & Check engine light on?
Old Oct 2, 2003 | 05:39 PM
Jimmyz's Avatar
EGR Code & Check engine light on...HELP?
I'm brand new to this forum. The car is a 95 GLE and is completely stock with 103,300 miles. Now, I'm a frequent poster on LS1tech.com cause I'm a Camaro guy too. This car is my dependable sales vehicle.
I don't have an ODB I tool to check the code but have taken it to a shop and they said it's got and EGR System code. They turned of the light and it comes back on in a few days. They told me its probably a clogged (carbon) EGR tube on the intake. Is there any easy way to fix this w/o taking off the intake to clean the tube? I just can't live with the check engine light on all the time.
The car is very well maintained. Please help.
Jim
Old Oct 2, 2003 | 05:43 PM
SXN's Avatar
SXN
check my signature...forum on the ECU, check your own codes and make sure they actually found the real problem, check all your own codes from now on
Old Oct 4, 2003 | 03:04 PM
Jimmyz's Avatar
Thanks for the suggestion and I'l try it. However, I was hoping for someone to tell me a way to clean this EGR tube that's slogged with carbon. Can I take off the vacuum tube and spray something in there to clean it out? I just don't want to pay $500 plus buck to a shop to R&R the intake just to clean out this tube teh EGR connects to on the intake.
Jim
Old Oct 4, 2003 | 03:14 PM
SXN's Avatar
SXN
i would imagine just spraying cleaner into it would push all the gunk back INTO the system. which tube is the EGR? Is that the egr port on the headers? so in theory that would push crud into the headers and y pipe? i dont see any problem with that, it would just get burnt off. someone please confirm
Old Oct 4, 2003 | 03:38 PM
Jimmyz's Avatar
I don't know enough about this car to tell you...if you're looking at the engine from the drivers side fender behind & below the TB is the ERG valve I'm talking about. Thinks some intake cleaner would suffice?
Old Oct 4, 2003 | 03:40 PM
SXN's Avatar
SXN
under the TB on the headers?
Old Oct 4, 2003 | 03:59 PM
Jimmyz's Avatar
No, I dont' think it's on the header.
Old Oct 4, 2003 | 04:45 PM
SXN's Avatar
SXN
well i was reading the forum about the new headers by nashua, and he said he needed to add the EGR port to the headers... figured it was the same one, but i could be confused. let me look in the haynes and chilton manuals, and i will post again later if i find something
Old Oct 4, 2003 | 05:29 PM
Jimmyz's Avatar
SXN - FWIW, my car is completley stock, no headers.
Thanks. Jim
Old Oct 4, 2003 | 10:27 PM
SXN's Avatar
SXN
lol..... your car HAS headers right? so you should have an EGR port
Old Oct 4, 2003 | 10:42 PM
Dave Holmes's Avatar
You can remove the EGR if you have the time. Instructions are in the Haynes manual, and I've done mine. You'll need to remove all of the stock intake plastic stuff to get near it. I had the throttle body removed, too, but can't remember if it was absolutely necessary (but did make it easier). It's not hard work, just a little time consuming (few hours) with the right tools.
Don't spray any cleaner in the EGR valve. There is a rubber diaphragm (or whatever soft material) in there that can be damaged by a cleaner. The Haynes manual even stressed that. The ports for the EGR can be cleaned by picking the carbon off with small, sharp tools, being careful not to gouge the mating surface. The tubes can be blown out with carb/tb cleaner safely. Don't forget about the gaskets, as they may stick to the engine and you won't see them.
Dave
Old Oct 5, 2003 | 07:48 AM
njmaxseltd's Avatar
Pull your own code and find out exactly what it's pointing to before you start ripping apart the EGR system. There are many components of the EGR system including vacuum actuators and sensors. What exact code did your mechanic pull from your ECU?
Old Oct 5, 2003 | 07:56 AM
ManualMaxima's Avatar
5th Gen till she dies!
this carbon build up does mess with your gas maileage and performance, I had a new throbble body postinoning sensor put in and they cleaned my all of the carbon out and it made pretty good difference.
Old Oct 5, 2003 | 05:31 PM
Jimmyz's Avatar
Don't know the exact code number it threw. I'll have to check and get back to y'all.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
