Its Lowered (pix) but engine problem?
Old Oct 5, 2003 | 11:11 AM
big_al's Avatar
Its Lowered (pix)
I just got er' lowered yesterday. H&R's and Illumina's.
I got a 0605 (#4 misfire). Car runs like poo. Anyone that had a code like this, what was the problem. I'm going to check the coil and injector.
I have a new spark plugs, fuel filter and the TB is clean.
Update: Replaced bad injector
Old Oct 5, 2003 | 05:46 PM
maxNYC's Avatar
Looks good!... now ya need a skirt kit
Old Oct 5, 2003 | 06:43 PM
Jatan's Avatar
Another IL person
For the misfire, make sure the coil pack is connected properly. Switch the coil pack from cylinder #4 with the coil pack in #2 or #6 and see if the code switches to that cylinder. If it does then it's the coil pack that's bad.
Old Oct 5, 2003 | 08:54 PM
big_al's Avatar
I think the injector is bad, The meter read 8 k ohms. the coil read fine but it wouldn't hurt to switch em' around. Thanks!
Old Oct 5, 2003 | 09:09 PM
BOZOnPJs's Avatar
looks great!.. how is the ride?
Old Oct 6, 2003 | 05:47 AM
big_al's Avatar
Right now the shocks are (2) all around. It rides great. Pretty dam close to stock minus the bounce.
After I get the car running good I'll rip some corners and play with the settings.
Old Oct 6, 2003 | 12:57 PM
lunchbox's Avatar
I had that same problem not too long ago. I changed the coil and everything is cool now. By the way, the car looks good.
Kevin
Old Oct 6, 2003 | 02:04 PM
my99maxisnice's Avatar
Did you have the rims on before lowering? If so, you have any pics of that?
Old Oct 6, 2003 | 02:06 PM
big_al's Avatar
Yes, no pix. It looked like ****, huge gap. that's why I HAD to lower it.
Old Oct 6, 2003 | 02:16 PM
jt151's Avatar
Intake
Is that an APEXI filter? What's the filter's mounting flange inside diameter (the side on closer to the engine)?
Old Oct 6, 2003 | 02:56 PM
ny96max's Avatar
not low enough IMHO...
Ant
Old Oct 6, 2003 | 03:03 PM
kyle13's Avatar
Ant
I would have gone lower also, there is still to much gap in my opinion. But it does look better than stock.
Old Oct 7, 2003 | 05:45 AM
big_al's Avatar
Yes, the actual filter doesn't have a flange, only bolt holes to mount a flange. The flange was included with the kit. The outer diameter is the same as the the outer diameter on the MAF, 3 in?? The wall thickness is like 1/8" so about 2.75".
This was only hours after the job. Since, the springs have settled lower.
Plus, I live near Chicago and the roads suck a$$. I like my settup and that's what really matters...right.
I changed my injector and so far so good.
Old Oct 7, 2003 | 04:08 PM
Jatan's Avatar
Lucky for us that they're repairing them, but they're so slow doing it
The street I live on was repaired a few months ago, but a few blocks down, the street is caving in already Plus there's like a million potholes in the alley. I can't wait til they fix it up
Old Oct 7, 2003 | 04:49 PM
Jepht20's Avatar
Custom User Title...
howcome you don't have the mystery box of the 95's?? the one that connects to the intake snorkel. pretty clean looking engine.
Old Oct 8, 2003 | 05:52 AM
big_al's Avatar
Are you talking about the box under the battery?
Its there.
Old Oct 8, 2003 | 05:54 AM
2DMax's Avatar
Pull the plug, double check it, make sure it's in right..just guessing here.
Old Oct 8, 2003 | 06:07 AM
big_al's Avatar
I replaced the injector. Its all good
Old Oct 8, 2003 | 07:52 AM
Jepht20's Avatar
Its there.
no, i'll get a pic of mine later today. it's right on top in the engine bay pretty much. connects to that thing that gets air from the outside that sits right where the hood meets the grill.
Old Oct 8, 2003 | 09:00 AM
big_al's Avatar
The resonator? I took it out cuz I got a midpipe.
homeyclaus
Sep 3, 2015 06:15 PM
maxocar
Aug 21, 2015 12:57 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
