Anyone need various plastic or metal parts chromed?
Old Oct 9, 2003 | 02:30 PM
PHSINVENT's Avatar
If anyone is interested I finally got my vacuum metallizing system going. I can pretty much chrome plate any part. Quick turnaround too! Just post and let me know.
Old Oct 9, 2003 | 04:58 PM
JNCoRacer's Avatar
Just the tip.
Hmm....if only you were in Texas.
Old Oct 9, 2003 | 05:07 PM
PHSINVENT's Avatar
What part or parts were you thinking of plating? The mail system doesn't take too long.
Old Oct 9, 2003 | 05:10 PM
Jepht20's Avatar
Custom User Title...
i thought someone said you can't chrome plastic? i don't know much about any of that but i read that once. how much do you charge for stuff?
Old Oct 9, 2003 | 05:14 PM
2naboy's Avatar
Yeah how much $$$ for it cause I have a couple of engine parts i would like to chrome out.
Old Oct 9, 2003 | 05:48 PM
kingrukus's Avatar
no more maxima...
The oem chrome grille and chrome handles are all plastic.
Old Oct 9, 2003 | 06:14 PM
zeff789's Avatar
You can chrome XBoxes too, and they are plastic... they are sweet looking.
Old Oct 9, 2003 | 06:50 PM
wariow's Avatar
got any pics of before and after chromed pieces?
Old Oct 9, 2003 | 06:57 PM
TylerBorg's Avatar
I can promise Brett (PHSInvent) is legit.
Old Oct 9, 2003 | 07:10 PM
gabex's Avatar
Would you possibly consider designing a chrome grill for the 95-96 like you did for the 97-99? I would be 1 definite buyer!
Old Oct 9, 2003 | 07:12 PM
Dave B's Avatar
Not DAVEB the parts guy
I would like to chrome the rear view mirrors so they look like the chrome Cefiro rear view mirrors. Are you game?
Dave
Old Oct 9, 2003 | 07:15 PM
JNCoRacer's Avatar
Just the tip.
I was wanting a total of 26 pieces chromed. That includes pieces under the hood and inside the car. I checked with a guy locally and he quoted me a price of $1530. If you can beat that, I may have to send these to you. By the way, can you do colored chrome?
Old Oct 9, 2003 | 08:17 PM
EZEMaxima's Avatar
do you have any before and after pics of plastic pieces chrome plated. I want to chrome plate quite a few pieces from the interior like the vents, radio trim, and the rest of the pieces that a regular dash kit overlays covers.
Eric
Old Oct 10, 2003 | 06:54 AM
PHSINVENT's Avatar
Actually not many people or companies chrome plastic. The old fashioned way is chroming steel, brass or copper. If you want to plate aluminum then you have to create a special copper substrate to allow the nickel to adhere to the copper. It's a layered process. I actually have three ways of chroming things so plastic isn't that bad. I can either vacuum metallize coat them or use a special chemical reaction spray or also plate the plastic with copper first then coat the copper. Long story but plastic can be done here.
Old Oct 10, 2003 | 07:02 AM
nupe500's Avatar
Jedi Knight
PHSINVENT,
if you have some pics of some of your work that would help.
Old Oct 10, 2003 | 07:07 AM
PHSINVENT's Avatar
Which engine parts do you want to chrome. Some parts under the hood will be easy if they are smooth to begin with. If they are rough then I'd have to do a lot of polishing first. Chrome really shows off what is underneath. It's similar to painting with all the prep work but the metal has to be smooth because chrome just doen't flow out like paint. It kind of loads up on the surface. I'll have a minimum of like $50 to start out. For example if someone sends me their brake fluid cap. I'd have to charge just $50 to do that since I'd have to prepare all sorts of baths just for one part. But if someone were to send me 3 or more parts then I'd charge around $25-40 for the small things and $100 for the larger stuff. Just let me know which parts you have in mind.
Old Oct 10, 2003 | 07:14 AM
PHSINVENT's Avatar
Colored chrome won't be a problem. If you want a factory body color match then I'd have to do some experimental color mixing to get the color to come close to your factory paint. $1530? That price is rather crazy. I can almost guess which parts you have in mind. The reason he is most likely charging you so much is because #1 chrome shops are rare nowadays and #2 he is only going to see you once so he is trying to get all your $ once since you won't be a repeat customer. Most shops are set up for larger size production runs. Plus the each and every part plates different and has to be carefully watched because if you leave a part in for two long then big globs of nickel will build up and ruin the whole job. I would never charge that much for your parts. Let me know which ones you have in mind. Thanks!
Old Oct 10, 2003 | 07:22 AM
PHSINVENT's Avatar
Eric
The plastic spark plug wire cover under the hood won't be that difficult. I'd charge $75 to do that part. I was also eye balling the heater vents in my maxima. My only concern was that there isn't much clearance for the movement of the vent parts. I might have to put a very thin layer on the vents. The radio trim and other pieces won't be that hard. I'll have to make up a list this weekend so you guys know what to expect as far as price is concerned.
Old Oct 10, 2003 | 07:27 AM
PHSINVENT's Avatar
Eric
I have a real busy weekend here. I'm in the middle of designing new grills and an underdrive pulley for the maximas and altimas. I'm going to plate some parts on monday and let you guys see what i'm talking about. If you guys want to see some of my past work then just log onto ebay and put "Motostorm" in the search box. I chromed all sorts of gauge rings and grills so you can check out my work. This chroming of plastic is a little bit different then just plating the gauge rings. I'll show you guys some pics on monday.
Old Oct 10, 2003 | 07:34 AM
JAY25's Avatar
if its easier to prep for a certain parts and makes it easier for you why don t you consolidate the parts say 5 people send you the same part so now your material doesnt go to waste and both you and the buyer benefit off each other, and also you will blow up amongst us and other forums to the point that you will be busy all your life chroming parts for everyone and not just the maxima guys. Just an idea for you
Old Oct 10, 2003 | 07:48 AM
1MAX2NV's Avatar
What about the spark plug cover? How much would that run?
Old Oct 10, 2003 | 10:47 AM
2naboy's Avatar
I was thinking about the intake manifold, crankcase cover and the valve cover not the plastic but the metal one. How much total for all three.
Old Oct 10, 2003 | 03:42 PM
PHSINVENT's Avatar
I would charge about $50-$75 for the spark plug cover. I haven't really done one yet but I have a good guess on how hard it would be.
Old Oct 10, 2003 | 03:46 PM
PHSINVENT's Avatar
The front valve cover is rather smooth to begin with so that one would be about $75. And I'd guess about $100 each for the other two. I'd have to sand and polish the intake and crank real good since they have that rough cast surface. Otherwise they wouldn't come out looking like a mirror. If you just wanted me to plate them how they are then I would charge about $50 for the intake and 50 for the crank. What would you drive if you sent those to me?
Old Oct 10, 2003 | 03:53 PM
PHSINVENT's Avatar
I like your idea about doing a larger quantity of the same part. But what part does everyone have in mind? I'd like to start with the plastic spark plug cover. If we got 5 people then I'd charge about $50 per piece. Keep in mind I will most likely do my cover and show you guys closer to monday of next week.
Old Oct 10, 2003 | 03:56 PM
PHSINVENT's Avatar
Dave
Are you talking about the side mirrors? Those wouldn't be that hard to do.
Old Oct 10, 2003 | 04:10 PM
brizsblackmax's Avatar
hey man what did that whole chroming shabang run for??
Old Oct 10, 2003 | 04:12 PM
PHSINVENT's Avatar
What chroming shabang are you asking about?
Old Oct 13, 2003 | 04:10 PM
the muta uckin chromeing shabang!
Old Oct 13, 2003 | 10:30 PM
PHSINVENT's Avatar
I'm not real sure. I never really added it up. It was $600 alone just for some resistance coils to heat up the aluminum evaporate solution. I'll have pics in about one day. Thanks
Old Oct 13, 2003 | 10:43 PM
96shogunmax's Avatar
Stillen fstb?
PR CAI?
radiator supports?
6 bolts?
Old Oct 13, 2003 | 10:58 PM
PHSINVENT's Avatar
Originally Posted by 96shogunmax
Stillen fstb?
PR CAI?
radiator supports?
6 bolts?
You are looking at like $100 for the fstb and cai. Are those radiator supports rusted at all? If not then add like $20 for the supports. So $120 for all those items. I'll have pics tomorrow night. I'm going to plate the plastic plug wire cover tomorrow.
Old Oct 13, 2003 | 11:02 PM
no rust on it. ill sand them for ya anyways. how much of a turnaround are we talking about? You gonna throw those 6 bolts in as well? FSTB bolts...
I dont see you on AIM or I would hit you up there..
Old Oct 13, 2003 | 11:20 PM
Nismo's Avatar
I have one of his grills and guage bezels and the chroming is excellent!
can you please quote me on the following-
(3) brackets radiator support, and hood sensor one
(3) caps- brake, power steering, coolant resovoir
and about 5 or so various brackets about the same size as the radiator brackets.
Old Oct 14, 2003 | 06:57 AM
PHSINVENT's Avatar
Hey how's it going? That grill is looking good. Are your radiator support brackets rusted? Everyone seems to want them done but I've seen quite a few that are rusted. I'd charge like $50 for those three caps and about $50 for the brackets. Post and let me know. I still plan on posting some pics later tonight. Thanks!!!
Old Oct 16, 2003 | 03:16 PM
Jepht20's Avatar
how much would you charge for the 95/96 stock grill?
and various parts from the interior, the dome light housing, the lights right above the rear view mirror(i think they're called map lights), the end pieces on the oh **** bars, and the piece that is above the seatbelts, the thing that is on the piece that slides up and down. sorry that's a bad description.
basically, how much for all those random small interior pieces??
Old Oct 16, 2003 | 05:47 PM
image's Avatar
I want my headers chromed!! w00t How much? is that possible?
Old Oct 16, 2003 | 06:01 PM
Jepht20's Avatar
would probably be cheaper buying cattman's aftermarket ones. they come chromed and will add a lil hp.
Old Oct 16, 2003 | 06:29 PM
TofuShop's Avatar
WOW ... i never realized that chroming could be so expensive! Well, if any of you guys live in NJ, SPI (the official Apex'i Power FC Tuning shop) can polish parts in your engine bay. my friend's RX-7 got done there and my brother's S14 is getting his motor swapped by them now. they gave him an estimate for $300 for getting whatever he wanted in his engine bay polished. Polishing and Chroming looks very similar .. and Polished is much lighter.. i think i'll get my engine bay Polished instead
Old Oct 16, 2003 | 06:52 PM
image's Avatar
how much for the headers?
