For the folks with rusted or stripped bolts on the cat
I just installed my new y-pipe, and during the process, I couldn't get one of the cat nuts off, but I didn't want to take it to the shop and pay 25 bucks for them to remove it for me (lazy I guess). Instead, I took off the entire cat and y-pipe together (remove hanger, heat shields, and of course b-pipe bolts) and dragged it out from under my car. I examined the bolt, and it ended up that I stripped it from trying so hard to turn it and of course it was a rusty nut. So that got me thinking, why don't I just get a 13mm socket, and hammer it onto the nut since I stripped it? So I gave it a shot. It turned out to work great becuase the bolt was rusty. I got the nut off (after several coats of PB Blaster, good stuff) and was able to reinstall the nut, because I made a new thread, but instead of it being 14mm, it's 13mm! I finished the install today, and no leaks, or bees in the can. The car picks up alot better in the higher RPM range, and sounds a little different, mabye in a subtle way, but not that much different from stock.
So if anybody has this problem when they're installing their y-pipe or a new cat, think of the new threading technique, even though it's not the best idea. At least drag the whole thing out from under your car (cat and y-pipe) and examine it, and see what you can do, you might be able to get some more torque on that nut with it removed.
Thanks for reading.
BTW, I got a warpspeed y-pipe.
Dan
Thanks for reading.
Dan
Originally Posted by ivelweyz
Or do it the easier way and get new bolts with nuts and some big, thick washers...
Heating up the stuck nut or bolt with a propane torch is the way to remove it without damaging it. Get it good and hot and use some penetrating oil after it has cooled a bit. Always works.
Originally Posted by gabex
Could someone please tell me where I can get ALL of the bolts from the y-pipe to the muffler?
litch
123
Jan 4, 2024 07:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
