climate control differneces
Old Oct 14, 2003 | 06:54 PM
driver824's Avatar
i have a 98 se and my climate control is burnt out. i saw thias one on ebay.. why is this one different??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437614418
thx
blake
Old Oct 14, 2003 | 06:58 PM
mzmtg's Avatar
Minister of Silly Walks
The other one is automatic climate control. You set the temp you want, and the system maintains it.
Before you ask, no, you cant switch them out.
Old Oct 14, 2003 | 08:07 PM
PoePoe2797's Avatar
Actually, wasnt it stated in the FAQ's that you CAN switch them, but it is a lot of work (ie. sensors, wiring...or something)?
Old Oct 14, 2003 | 09:29 PM
driver824's Avatar
well i guess i need to find the correct one.. wht exaclty do u call the one that maintaines the temp..
Old Oct 14, 2003 | 09:35 PM
SXN's Avatar
SXN
ah, so you finally decided the climate control was toasted? try finding a direct replacement (and while its out, consider changing all the LEDs to be a cool color )
Old Oct 14, 2003 | 09:36 PM
MONTE 01&97 SE's Avatar
It may look different to you because that face plate is from a 95-97 Maxima with automatic climate control, in 98 Nissan revised the face plate. In 99 they added to the ambient button to the revised one. So if you have auto climate control it might work, but i would go for an 98 or 99 one to be on the safe side if you alredy have auto climate control.
Old Oct 14, 2003 | 09:38 PM
driver824's Avatar
so the 99 has the AMB button stock? and im def gonna change the leds to blue, but as of right now my baby is dead again. the battery died again and the weather here is rainy so i cant charge her up..
Old Oct 14, 2003 | 09:48 PM
Yes the 99's with auto climate have the ambient button!
Old Oct 14, 2003 | 09:50 PM
SXN's Avatar
SXN
so you never sorted out the battery or the climate control problems?
Old Oct 14, 2003 | 10:06 PM
driver824's Avatar
no not exaclty. the car sat for a day and then i went to try sum stuff today and it was dead.. so im gonna charge the battery, disconnect the climate controls and bring it to the shop to get an exhaust leak fixed then try to find a climate control at a junk yard by me by friday for a mini meet i got planned friday night... think ill pull it off..any bets...
Old Oct 15, 2003 | 05:47 AM
Prodeje79's Avatar
so for the record.....
there was just a design change from 97 to 98?
Which means I could use an auto climate control from a 98 to replace my auto climate control in my 97?
thanks
Old Oct 15, 2003 | 07:10 AM
techie's Avatar
If you end up finding a 98 unit used you can always add the AMB button for about $5. Since you will have the control unit out already, a 1/3 of the battle is already won.
Old Oct 15, 2003 | 07:11 AM
MaxedOutOfCash's Avatar
Pizda Boy
True. . . I did it. . .check my website for picture. . . the button cost me around $7 at the dealership and took me 15 minutes to do.
Old Oct 15, 2003 | 08:22 PM
hitpro's Avatar
Did yours actually work? If so, then how did you get it to work? I have a 1998 GLE and it seems as if the spot where your AMB button is, is non-functional.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
