transmission or something else ???
i have a problem here
it just started to happen today
it happend twice today
i barely press on the gas and the needle jumps to 4500 to 5000 rpm's before shifting.... all this happen for about 1 sec and then everything come to normal... is it my transmission??
i have a automatic 98 gle
Originally Posted by indigomax
i think is your valve body and the preassure of the tranny is going bad(you should check it asap)
If you have to press the gas that means the tranny need more preassure to engange.
what i meant to say is that whenever we press slightly on the gas pedal ... the rpm usually go to 2500 to 3000 rpms, but with me it happend twice today that i pressed on the pedal and the rpm jumped to 4500 rpms... which is not normal
yes, i have a problem with my tranny...before rebuilt, i use the car like 2 days with the problem....after the tranny rebuild, they told me that the dirty of the tranny damage my VB, and just for a few miles etc. The VB is very easy to go bad, more if you have a tranny problem like that.
so if my VB is bad, i gotta rebuild the tranny ???
Originally Posted by Maxima99SEbose
no no.. just get the VB replaced.. unless you drive around too much with it and cause permanent damage.. Mine drove about 10 miles on a busted VB, then had it towed to the stealership and it didn't cause any permanent problems.
Pied
Sep 26, 2015 03:29 PM
