My first Mod maybe a y-pipe?
Old Oct 21, 2003 | 09:54 AM
XoPtOn's Avatar
i just got my 1999 maxima gle ladt month and i wanna start hooking it up and i saw that a y-pipe gives you a good amount of horse -power like warpspeeds y pipe, so ive been thinking of buyen it but i just wanna know if it is okay if i buy one and if i need some thing else first before i buy one. I dont want to buy one and find out its not gonna work good without a _____. so if any1 can give me some info if its okay to buy a y-pipe as my first mod?sd
Old Oct 21, 2003 | 10:07 AM
LiquidNine's Avatar
a Y-Pipe was my first mod as well.
Verify if you care is fed or cali spec prior to purchasing the Y-Pipe - you should not really *need* any additional parts to install it. Ask the place you buy the Y from if it comes w/ all the necessary gaskets. When you install, put anti-seize on the O2 sensor threads.
An intake w/ better flow properties will help take advantage of what the Y-Pipe has to offer. Have fun looking at page after page of 'Best Intake Type' debate!
Old Oct 21, 2003 | 04:26 PM
NmexMAX's Avatar
dot dot dot ...
I would, it wasnt my first mod, but I it's a good start.
Old Oct 21, 2003 | 04:44 PM
XoPtOn's Avatar
how do i know if i am fed or cali?
Old Oct 21, 2003 | 04:45 PM
Taken2DaMax's Avatar
Y-pipe is a great first mod...
I went with a Budget Y-pipe, it's the best bang for your buck. And it does the same as any other y-pipe out there.
Old Oct 21, 2003 | 04:48 PM
Jeff92se's Avatar
I'm needing a caw
REAR SWAY BAR. ADDCO OR CATTMAN UNIT! You will thank me later!
Old Oct 21, 2003 | 04:59 PM
Tight_Whip's Avatar
My First mod was my Place racing CAI, which i noticed instant gains.
I am just now Adding my Y-pipe (warpspeed) Which is the second most thing you can do to add hp.
I recommend buying a Cold Air Intake First...
Reason
You get just as much HP as a Y-pipe, accept CAI provides your maxima with a Beautiful Growling sound when WOT(Wide Open Throttle) It makes your maxima sound like it has a monster under the hood.
Check out my thread about which Y-pipe is the best to get if you decided on a Y-pipe any how, though i really do suggest buying an Injen CAI first.
My Place Racing CAI:
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if you have 3 02 sensors then you are fed. if you have 4 then you are cali. pop the hood and check right in front of the engine.
Old Oct 21, 2003 | 05:18 PM
XoPtOn's Avatar
thanks for the posts guys, i really appreciate your opinions on this, one more question do you guys think i should buy some rims or buy a mod like a cai, y-pipe cause i been saving up for rims already and i could buy a y-pipe and a cai
Old Oct 21, 2003 | 05:21 PM
Tight_Whip's Avatar
Which do you want more? Looks? or Speed? If i were you I'd do the Y-pipe and Injen CAI. Thats about $430.00. If you want rims, goto www.WheelMax.com
They sell Wheels & Tires MAD CHEAP!
Old Oct 21, 2003 | 11:06 PM
topdog1207's Avatar
im also going to be getting a y- pipe soon. I have a 95 gle. Would this be fed specs? or cali? im confused. Sorry guys, im new
Old Oct 21, 2003 | 11:28 PM
KsuMax's Avatar
Cheesing away...
Don't remember where it is in the VIN but the vin tells you what you are fed or cali. I personally would go intake first, then y. Or get them both at the same time.
Old Oct 21, 2003 | 11:45 PM
USDM-A32's Avatar
Well, what are your plans with the Max? Show or go? Since you have a GLE, your going to be limited to performance when you don't have a manual transmission. You can go and spend all your hard-earned money on performance intakes like Injen and Place Racing, but for what, like 4 horses? And the y-pipe, what like 7 horses? If your going for performance, your 1st mod should be a 5-speed swap, if your mechanically inclined, you should spend no more than a few hundreds and that 5-speed swap is altogether better than a y-pipe/intake/underdrive pulley/cat-back exhaust on an automatic Max. If you can't do it, look about spending $1000 on parts and labor, but that's up to you to decide if performance is what your looking for. If you decide to just skip the swap, yes an aluminized Warpspeed y-pipe is a good choice. Since you don't have the stock fog lights, a Place Racing intake would be cool, but I prefer the Place Racing intake without the cold air extension, for peformance, that is the best setup intake-wise. Those mods alone should give you somewhat noticeable gains, but like I always say, naturally-aspirated performance is for the weak, boosted is the way to go. Oh yea, and depending on the number of plugs in front of your valve cover could determine if you have a cali-spec.
Old Oct 22, 2003 | 04:30 AM
LiquidNine's Avatar
From the 4th Gen FAQ's
Raise your hood. Look for a shiny metal identification tag fastened to the passenger side of firewall. The top row is the Vehicle Identification Number, starting with J. The second row is model information. The first five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
Credit: Daniel B. Martin
Old Oct 22, 2003 | 09:48 AM
XoPtOn's Avatar
i want it for show and go lol, any1 else have a 1999 maxima gle and hooked it up with a cai and y pipe and how much did you feel the performance gain?
Old Oct 22, 2003 | 04:11 PM
XoPtOn's Avatar
k i still cant tell if im cali or fed
Old Oct 22, 2003 | 05:09 PM
USDM-A32's Avatar
You will feel it especially if they are both installed at the same time to feel difference from stock. It might not be much, but there is an improvement. Those are the 1st 2 naturally-aspirated mods to get, best bang for the buck.
Old Oct 22, 2003 | 05:12 PM
XoPtOn's Avatar
k im not sure what a 02 sensor is so im gonna show you a pick and say if thats it
[IMG][/IMG]
Old Oct 22, 2003 | 05:21 PM
USDM-A32's Avatar
[IMG][/IMG]
Yea, that's cali-spec.
Old Oct 22, 2003 | 05:24 PM
XoPtOn's Avatar
okay thanks
Old Oct 22, 2003 | 05:29 PM
USDM-A32's Avatar
okay thanks
For reference, look at Tight_Whip's engine bay pic above, and see the difference in number of o2 sensor plugs.
Old Oct 22, 2003 | 05:32 PM
XoPtOn's Avatar
the thing to the right of the oil check stick?
Old Oct 22, 2003 | 05:35 PM
USDM-A32's Avatar
No no, the plug right below the "3000" on his spark plug cover.
Old Oct 22, 2003 | 05:38 PM
ereet's Avatar
Cripes, USDM-A32 where are you getting this information? A few hundred for a 5 speed swap if you're mechanically inclined? Seeing as how most transmissions go for $500+ alone, you're looking at a HELL of a lot more than a "few". Clutch? There's a "few" hundred as well. I'm not even going to get into the little parts like trim, pedals, etc.
The intake should give 3-6 horsepower, the Y-pipe will give 12-18 on average. The y-pipe was my first mod, followed by an intake and rear sway bar, and other than the supercharger, they were by far the most noticeable.
Old Oct 22, 2003 | 05:40 PM
XoPtOn's Avatar
ya thats what i meant
Old Oct 22, 2003 | 05:42 PM
XoPtOn's Avatar
any1 know how i can show a pic without a link?
Old Oct 22, 2003 | 08:11 PM
Ladzio's Avatar
easy.... disregard *(stars), used them so it does not turn it into link
[*url=*your link goes here*]My Picture[*/url*]
Old Oct 23, 2003 | 10:05 AM
XoPtOn's Avatar
[ url=http://www.cardomain.com/member_pages/show_image.pl?migration=1&image=http://images.cardomain.com/member_images/11/web/443000-443999/443186_4_full.jpg]my pcture[ /url ]
Old Oct 23, 2003 | 11:36 AM
Ladzio's Avatar
There should be no spaces either
engine bay
Old Oct 23, 2003 | 03:46 PM
XoPtOn's Avatar
not like that i dont want to show the link i want to show the pic like tight_whip on top
Old Oct 23, 2003 | 04:40 PM
Tight_Whip's Avatar
I just installed my Y-pipe from warpseed, I haven't noticed that mnuch of differnce to tell you the truth. I noticed more of a drmtic difference with my PR CAI. But, i heard that i have to wait for my Y-pipe to set in... Well, see on my 60 mile trip home. will repost after and let you know. There are bees in a can unlike warpseed says... Dont listen to anybody they always have bees in a can, "i'm pretty sure."
Old Oct 23, 2003 | 05:44 PM
Ladzio's Avatar
I see, then show the link to the pic on the server and not to the page that contains this pic. It's the part where second http address starts.
[*img]http://images.cardomain.com/member_images/11/web/443000-443999/443186_3_full.jpg*[/*img]
and here you go (omit stars)
Old Oct 24, 2003 | 08:11 AM
Tight_Whip's Avatar
Xopton, I really do suggest you getting a Injen CAI first. You get the most power out of an CAI. I just Installed my Warpspeed Y-pipe yesterday, and it has settled in yesterday. The only time you notice power from a Y-pipe is Mid-High Range thats 3500rmps -6000rpms, it doesn't give you pick up.
Old Oct 29, 2003 | 08:08 AM
Brudaddy's Avatar
Does Budget y-pipe come with all gaskets or Pre-cats or whatever it is supposed to come with? I don't really know...new to that.
Thanks,
Old Oct 29, 2003 | 09:33 AM
Brudaddy's Avatar
Also, will installing y-pipe cause check engine light to come on if that is the only performance mod? If so, what do I need to do?
Old Oct 29, 2003 | 09:35 AM
XoPtOn's Avatar
thanks for the info guys, i should get my injen cai on thursday and my y-pipe on friday
Old Oct 29, 2003 | 10:00 AM
ereet's Avatar
My budget Y-pipe came with all gaskets (although they're not nissan ones). The y-pipe removes all pre-cats and therefore isn't emissions legal (however, you SHOULD pass emission with it, depending on if they do a visual). And no, shouldn't get check engine lights either.
Old Nov 9, 2003 | 04:36 PM
XoPtOn's Avatar
got my injen cai and ws y pipe installed and its great but i dont know what should be my next mod so any1 know whats after a cai and a y pipe?
Old Jan 29, 2004 | 03:46 PM
Brudaddy's Avatar
I didn't end up getting a y-pipe from Budget, but bought a stillen one from maximumpower96. He recommended to just get new gaskets and stuff. Do you think I should and if so, where would be a good place to get them? NAPA? what do I ask for?
Thanks for your comments...
Old Jan 30, 2004 | 08:55 AM
budha56's Avatar
I think he said SWAP, meaning if someone will trade tranny for tranny. Then there's no (low) parts cost.
