knock sensor
Old Oct 24, 2003 | 07:33 PM
coryf's Avatar
knock sensor
so there i was...engine light came, i diagnosised it and got a knock sensor code. not the first time, but curious whether i should replace it now or wait till i do all the O2 sensors too. any suggestions, i would love to get better gas mileage so maybe i should just shut up and do it.
help
Old Oct 24, 2003 | 07:45 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
yes, just shut up and do it.
Old Oct 24, 2003 | 09:58 PM
ivelweyz
Do you have O2 codes? If not why would you change them? If you do change them and the KS code should be gone as O2 codes set off the KS code. If you have the cash however just buy them all...
Old Oct 25, 2003 | 11:19 AM
UncleMax98's Avatar
Since the engine light is on, there may be other problems in addition to the KS code. If you fix the other problems first, the KS code may go away by itself.
Old Oct 25, 2003 | 01:47 PM
NissanMasterTec's Avatar
The first thing you need to know is that the knock sensor will not turn on the light. there must have been other codes stored along with the KS
Old Oct 25, 2003 | 01:53 PM
ivelweyz
NooB you're wrong. If the KS is bad it will have a ghost code. Like the guy said he saw the code when he checked them, not that it started flashing by itself. Like I said why are you replacing other sensors if you don't have codes for them???
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
