Quick ? about the PCV valve...
Old Oct 27, 2003 | 06:21 AM
MaximaEvolution's Avatar
What fluid flows through that valve? I cleaned it yesterday and there was what looked to be carbon build up.
BTW: After cleaning that valve, and adjusting my throttle cable, the car pulls harder and my hesitation is gone. If you have any hesitation at all, I would deffinetely suggest doing what i've done.
Old Oct 27, 2003 | 06:32 AM
mzmtg's Avatar
Minister of Silly Walks
Air is the fluid that flows through the valve. PCV stands for Positive Crankcase Ventilation. The valve vents hot gasses from inside the engine block to the intake, where they can be burned.
Old Oct 27, 2003 | 06:34 AM
cool . Are there any other valves like that one where i can clean them to help the engine run better?
Old Oct 27, 2003 | 06:48 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
its not a valve but you could clean the throttle body. see the how to on motorvate.ca. this will get gunked up from air coming from the filter and from the crankcase tube leading into the stock resonator.
Old Oct 27, 2003 | 11:43 AM
Jatan's Avatar
You did replace the PCV valve right? Or did you just take it out and clean it like you said?
Old Oct 27, 2003 | 01:15 PM
nismology's Avatar
If it still can rattle around freely in it's housing, it dosn't need to be replaced yet.
Old Oct 27, 2003 | 02:14 PM
When i first took it out,it was not moving, i cleaned it with some WD-40 and a little lung power. When i was done it moved as freely as a brand new one. And as mzmtg said, hot gasses pass through it so i figured that it will just burn up any excess WD-40. . I cleaned the throttle body once before, but i dont think i did it right. I'll have to give it another try.
Like i said in the first post, after i cleaned the PCV valve, and ajdusted the accelerator cable, all my hesitation went away and the car pulls harder at a dead stop, as well as at 30, 40, 50+ mph.
Old Oct 27, 2003 | 09:08 PM
mad-max98's Avatar
what happens if you disconnect the hose carrying the gases back to the intake how will that affect the performance
Old Oct 28, 2003 | 04:56 AM
sloppymax's Avatar
it will not have any difference on performance. you can cap it off with a k&n style crankcase breather filter. it will help clean the throttle body and manifold cleaner over time but it also allows for unmetered air to be released and some people debate over whether that is negative or makes no impact.
Old Oct 28, 2003 | 05:07 AM
mzmtg's Avatar
No.
You can get a filter to go on the valve cover breather, but no the PCV. You will gte hesitation and such of you cap off the PCV. The valve must be left in place.
Old Oct 28, 2003 | 05:11 AM
sloppymax's Avatar
Originally Posted by mzmtg
No.
thats what i meant. i should have worded it better but i wasnt talking about capping off the pcv. i thought the post i responded to was talking about the crankcase hose from the crankcase to the stock resonator, at least by the way he worded it.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
bumpypickle
Sep 20, 2015 08:22 AM
