removing and replacing gauge needles on 99
Old Oct 27, 2003 | 09:24 PM
s2cmpugh's Avatar
sup guys, i have my 2nd cluster here and im debating on getting the needle kit, mainly so my needles will be brighter and easier to see...BUT I have a few questions regarding the removal of the needles. i found this link http://forums.maxima.org/showthread....hlight=needles which makes sense, BUT how do i physically remove the needles? Do i just pull up on them or do i use this whole calibration point thing??
SO i did a test using the other method where u remove the needle stop, and let the needle fall down to where it stops. then u make a mark, and start turning counterclock wise and pull up on it. so i did all that and the needle came off fine and put it back on and followed the directions. now my question is this....if i remove the needle stop again and i have to push it down to the point where resistance starts AND its at the same point, did i install it right????
also how do i remove the fuel and temp correctly so as to not break them..
thanks
Cris
Old Oct 28, 2003 | 06:32 AM
s2cmpugh's Avatar
come on guys, someone knows something about this...
Old Oct 28, 2003 | 02:20 PM
s2cmpugh's Avatar
ttt once again
Old Oct 28, 2003 | 02:30 PM
MaximaZX's Avatar
sorry, i dont have the slightest clue, but free bump for you
Old Oct 29, 2003 | 07:48 AM
s2cmpugh's Avatar
one last time
Old Oct 29, 2003 | 08:20 AM
clee130's Avatar
See if this helps:
http://web.archive.org/web/200210142...shinstall.html
Old Oct 29, 2003 | 08:31 AM
s2cmpugh's Avatar
thanks clee, that does help actually...... but im curious if that process works for a 99, and if i do everything correctly, and i remove the needls stop again, and it falls to my calibration point, did i do it right?
Old Oct 29, 2003 | 08:42 AM
clee130's Avatar
Yes it works for a 99.
If you did everything correctly and followed those directions, and it falls back to the calibration point, then you did it right.
It's not as hard as you make it sound. I did it several times when I had my indiglo gauges and as long as you take your time and follow Cheston's directions, you'll be fine.
Old Oct 29, 2003 | 08:53 AM
s2cmpugh's Avatar
thanks man for the help, although im still a little shaky on temp and gas, can u clarify that for me??
thanks
Cris
Old Oct 29, 2003 | 06:39 PM
s2cmpugh's Avatar
any other suggestions for the temp and gas, those are the ones im worried about now
MattWithTheMaxima
Jun 30, 2017 01:06 PM
Rage Maximus
Sep 3, 2015 12:26 PM
Justinmc760
Aug 23, 2015 03:10 AM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
