Need Rim EXPERT
Old Feb 20, 2001 | 09:18 AM
Naughty
I am looking into buying some rims for my 98 MAXIMA. I found some that i like and was wondering if they would fit my CAR. The Bolt Pattern is 5X114.3 . However, I dont know the OFFSET for the rims....Does the Offset matter if the Bolt Pattern fits?? Also the rims I am looking at came off of a 96 Explore / and were also on a 91 Ford Probe. ( The rims are 17's)......
Thanks!
Old Feb 20, 2001 | 10:21 AM
plrod Black 95 SE's Avatar
First I must advise you that I am no "Rim Expert"
I once mounted 16" Pony wheels on my my 95 and the fit fine; I don't know what the offset is but it's from a rear drive car which is the situation you have.
I wouldn't pay alot for those rims as there are rim specials around where you can get 17's for less than 100 bux a piece. check out discountire.com
I just picked up a set of 17x7 enkei fubuki's for 90 bux each
Old Feb 20, 2001 | 11:04 AM
Naughty
The rims I am looking at Are NICHE BELLA's (Chrome). The Guys is asking $900 is that to much for these rims???
Old Feb 20, 2001 | 11:35 AM
I don't know about that price. It may or may not be good. Only thing else I can suggest is if you're going to buy them, have em spun w/o tires to verify they are good.
Old Feb 20, 2001 | 11:54 AM
ybelm620
that is not a bad deal, but how much tread is left in the tires
Old Feb 20, 2001 | 12:52 PM
madduck99
i'm no expert either, but the wheel width is important as well, try looking at tirerack.com they can probably answer your offset and other questions
Old Feb 20, 2001 | 04:25 PM
Naughty
Rims are Nich Bella's 17x7.5 and the Bolt Pattern is 5X114.3. 80% of the tire is left ...for a total $900 for everything.
1) Is this a Good deal?
2) Should i be worried about the offset or it doesn't matter then the Bolt Pattern Fits?... Do the same Bolt Pattern come in Differnt offset's ?????
3) And the tire is 225/45/17
As you can see I am Confused! help! Can all this work?
[Edited by Naughty on 02-20-2001 at 06:29 PM]
Old Feb 20, 2001 | 04:44 PM
Shingles's Avatar
The missing moderator
you know, the FAQ has the information you are looking.
Old Feb 20, 2001 | 06:50 PM
Naughty
I looked over the FAQ , but it doesn't really address my questions. With 5X144.3 bolt pattern is the offset predermind by the manafacture? or does it varry? 225 tire should work ? right...
litch
123
Jan 4, 2024 07:01 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
