how do you turn off the service engine light
Originally posted by juice
The service engine light came on and i want to know how to turn it off because i dont feel like dealing with nissan
"something" may be any number of things, some major and some minor. It
might be nothing more than a loose fuel filler cap. The Engine Control
Module (the computer) detected a problem and turned on the Check Engine
Light. At the same time it stored one or more Diagnostic Trouble Codes.
Get someone to do a DTC readout for you. This is not a big deal, does not
require specialized "dealer only" test equipment, and should take less than
an hour. When you know the stored DTCs, you will have a fair idea of what
repairs are needed.
If you like to do your own "wrenching" you can do the DTC readout for
yourself. Go to your public library and borrow a Chilton's or Haynes
manual for your vehicle. It contains detailed instructions and a table
which "translates" the numerical codes into words. No special tools are
required.
You will also find instructions to do a DTC readout and reset
the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
If you just reset the light without doing any real diagnosis and repair you may expect the light to come back on sooner or later. Probably sooner.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
